Narrowed it down, still need some help - BMW Forum - BimmerWerkz.com
Old 01-08-2004, 05:58 PM   #1 (permalink)
Wurzig-Drei's Avatar
Wurzig-Drei is an unknown quantity at this point
Send a message via AIM to Wurzig-Drei
I'm still having problems with my heat but iv narrowed it down. I replaced the heater control unit. But that did nothing, it wasnt broken in the first place. And if you listen really close you can hear the actuall valve switch from hot air to cold air, so thats not broken. I now have no clue as to what it can be. Its not the speed switch because that works when the a/c is on. Anything?
Under construction
Wurzig-Drei is offline   Reply With Quote
Old 01-09-2004, 10:53 PM   #2 (permalink)
So no ideas. What other parts are there to the heater in a BMW. More sensors and relays im sure.
Under construction
Old 01-09-2004, 11:12 PM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
i really hated HVAC dude its not my best field sorry..
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-09-2004, 11:36 PM   #4 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
By saying "heater control unit" I am assuming you mean the heater valve in the engine bay. I believe I said in an earlier post that the vehicle has 2 seperate blowers(one for a/c and one for the heater). If your blower does not work when the a/c is off, then you have a bad blower.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Old 01-10-2004, 04:29 AM   #5 (permalink)
By heater control valve i mean the temp knob. And I only have 1 fan that i am aware of. It is in front of my shifter. Iv taken the casing out and there is only one fan present. Unless there is another fan under the hood. That could be it, i will check.
Under construction
Narrowed My wheel Choices Help ! Nunzio 3-Series (E36) 40 08-17-2004 09:24 AM
