My Gongs Gone...... - BMW Forum - BimmerWerkz.com
Old 11-13-2004, 08:57 AM   #1 (permalink)
machinehead's Avatar
machinehead is an unknown quantity at this point
Send a message via MSN to machinehead Send a message via Yahoo to machinehead
Thumbs up
for some reason the warning gong has stopped working but the display still shows the warning ok. the part number for the sounder is 65.81 8 350 349 but I cannot find this listed.
I checked the 12v feed and that is there fine. there are 3 other terminals T1 T2 and T3 which I guess trigger different sounds.
I guess this is not a comman problem?
Does anyone know how to test the device, or the wiring?
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Arial'>because life's too short not to..........</span></span></span>
machinehead is offline   Reply With Quote
Old 11-13-2004, 09:38 AM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
[snapback]229979[/snapback]
u mean the thing making the ding when you move off and your door is open and such ?
Old 11-13-2004, 10:02 AM   #3 (permalink)
That's exactly the thing I mean
Old 11-13-2004, 10:27 AM   #4 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
yeah, that things annoying
xsperf is offline   Reply With Quote
Old 11-13-2004, 10:56 AM   #5 (permalink)
the thing is, I actually want it to be working!
Old 11-13-2004, 11:34 AM   #6 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
what's weird is that i just finished checking the online parts catalog and that part is not listed (at least not under the number thats on the back of it).
Old 11-13-2004, 11:38 AM   #7 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
i'll call a local dealership monday and ask about if they know how much it is and what the actual part number is... just tell me what year ur car is.
Old 11-13-2004, 12:50 PM   #8 (permalink)
it a 1993 525i e34. A German website I looked at (search Google with the part number!) had the same thing, pt no. not listed. its not in my listing either.
must be somewhere, trouble is I have no wiring diagrams, nor info to test.
it only stopped working after the last service - I don't know if it can be turned off some how?
Old 11-16-2004, 06:28 AM   #9 (permalink)
Torque, how did you get on with the local dealer?
has anyone elase got any idea on this?
Old 11-16-2004, 10:52 AM   #10 (permalink)
Moderator
Dirty_Tool's Avatar
[attachmentid=15142]
This attachment help? Of course the first thing to do would be to check fuse #20 then go from there.
Good Luck
DT
P.S X518 is the 4-pin black connector, X522 is the 3-pin white
DT
Old 11-16-2004, 02:45 PM   #11 (permalink)
fuse is ok, this does the clock if I'm right, and there is 12v on the white connector too and ground too.
At least I know now from the diagram that the terminals T1 through T3 are grounded to trigger the appropriate sound. I will try earthing each through, say a 10K ohm resister and then reduce this, to see if I can get them to trigger a sound from the Gong, if I cant get a sound then I guess that the Gong must be dead, otherwise the loom or the OBC is at fault, bugger.
Thanks for the diagram tho
Old 11-17-2004, 11:43 PM   #12 (permalink)
Moderator
Dirty_Tool's Avatar
You're Welcome,
Sounds like you're very competent with electrical, Im sure you will get this fixed easily.
Good Luck,
DT
DT
Old 12-05-2004, 08:11 AM   #13 (permalink)
Well, I've eventually got time to have another look....
12v is supplied OK. Earthing any of the terminals T1 through T3 produces no sound what so ever from the device - guess it must be dead. Will try and find one on Ebay or somewher and try substituting it, unless anyone has any other ideas?
Old 12-29-2004, 09:19 AM   #14 (permalink)
Well, still no sucess on this one. My brthoer has two E34 525's now, an earlier 12v and newer 1992 24v M50 (same as mine) neither have a working gong. Having searched other forums too there does seem to be various carsthat have this working,or not. I'm reluctant to buy a 2nd hand gong as this may/maynot work!
Does anyone know whether the gong units fail on a regular basis or whther its a frequent OBC failure? Is there possibly something that could have been set/reset at the last service, even if in error, that has disabled the gong? Its annoying as I've nearly got out and left the lights on when the mornings have been semi-dark (enough to use lights to be seen, rather than to see, if you know what I mean...)
PS: Happy new year to you all
Old 01-01-2005, 03:12 PM   #15 (permalink)
kcld is an unknown quantity at this point
I just finished repairing my gong. There is a 2", 8 ohm speaker in the bottom of the plastic housing under the printed circuit board. Mine appeared OK but when I simply replaced the small speaker, the gong works fine now. If you look along the sides of the plastic housing, you will see small tabs you can push in with a screwdriver to remove the circuit board to gain access to the speaker. I got mine from:
http://www.allelectronics.com/cgi-bin/cate...-820&type=store
But a 2" PC speaker should work.
Good luck!
kcld is offline   Reply With Quote
