My German spec E34 issue's list.... - BMW Forum - BimmerWerkz.com
Old 09-08-2008, 11:01 AM   #1 (permalink)
TxAg98 is on a distinguished road
Ok, I just picked up a 1991 German spec 525i with about 180k km on the ticker. Here are my issues:
1) It has developed a surging idle while stopped. I have been told that this is the idle air control valve that needs to be cleaned. Will be doing that this weekend. Will also be replacing air filter, fuel filter, plugs, oil change, and bleed and check brakes.
1a) While under the hood, I noticed that my MAF plug was not fully seated on the MAF sensor. So I plugged it in and seated it properly and my car instantly developed a very "lumpy" idle and then stalled. When I unplug my MAF sensor it goes right back to the surging idle. Does this mean that my MAF is bad? That would be my guess.
1b) When you unscrew and unplug the MAF sensor, the sensor end has like 7 pins or something, I didnt count. The plug that comes off has the corresponding holes. I know this may be a dumb question, but on the plug end, only some of the holes have metal contacts down in them. Is every hole supposed to have one of those metal contacts to make contact wth the sensor end?
2) The car is German spec, so all messages on the dash are obviously in German. It is showing two. First is "Bremsflussigkeit", which I found in the german manual as low brake fluid. Will address that this weekend when I do the brakes. Other is "Betriebsanleitg." I cant find that on anywhere in the manual. Anyone speak German or have a German spec car that you know what this means?
TxAg98 is offline   Reply With Quote
Old 09-08-2008, 03:02 PM   #2 (permalink)
MEDSTUDENT87's Avatar
Car: '90 525i
MEDSTUDENT87 is on a distinguished road
Send a message via AIM to MEDSTUDENT87
I am pretty sure it basically says what the English versions would say "Brake linings." Which means the brake pads are worn out. It has been really long since I have spoken/read german. So don't quote me.
MONEY DOESN'T BUT HAPPINESS BUT CRYING IN A BMW IS MORE COMFORTING THAN CRYING IN A KIA!!!!
MEDSTUDENT87 is offline   Reply With Quote
Old 09-09-2008, 02:48 AM   #3 (permalink)
denyo77's Avatar
Car: 88 325iT, 88 320i, 92 325iC, 89 190
denyo77 is on a distinguished road
Betriebsanleitung means manual
Bremsflüssigkeit is brake fluid
if you have any other questions, don't hesitate to ask
brake linings/pads would be Bremsbeläge
denyo77 is offline   Reply With Quote
U.S. Spec to Euro-Spec Conversions FraneSosic New Members Check In 0 06-24-2008 02:10 PM
German anyone??? crawlermonkey M-Series (M1, M3, M5, M6) 9 01-20-2008 06:50 PM
1992 325i: US-spec vs UK-spec Cod 3-Series (E36) 1 11-27-2006 02:54 PM
Im german e36_m3_Turbo Video Vault 12 11-02-2004 08:50 PM
Import German spec 1989 535 Black 535 5-Series (E12,E28, E34, E39, E60) 0 01-23-2004 05:10 AM
