my car keeps missing at 1500-2000 revs - BMW Forum - BimmerWerkz.com
Old 09-28-2009, 12:09 PM   #1 (permalink)
Car: BMW 520D E60 55 REG
tids is on a distinguished road
hi all i have a bme 520d e60 55 reg
the prob is that it keeps missing at about 15000 to 20000 revs not all the time if you put your foot down it clears it happens in all gears as far as i can make out its been doing this for a few weeks and as time gos bye more and more aften
ave renewd air fillter and the fual fillter and ran the tank all most emty put redx in and evan used other fule surpilers just can not put my finger on the prob can any one help plzs
tids is offline   Reply With Quote
Old 09-29-2009, 04:07 AM   #2 (permalink)
Hi me agen on start up this
morning the car was doing the same from cold then when it got warm was ok for a bit then was doing as I but in the post above help me plzs
Old 09-29-2009, 07:35 AM   #3 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
carguy13 is on a distinguished road
i'm guessing you mean, 1500 to 2000 rpm?
is there a check engine light on?
carguy13 is offline   Reply With Quote
Old 09-29-2009, 02:53 PM   #4 (permalink)
yer i do m8 no there no lights on
taken some pits off today to ave a good look around to see if i could see owt out of the nor
when i taken the pip off that comes from the turbo intercooler to the throttoe body i seen bits of oil and dry oil so i looked up the throttoe body and that was the same is this normal or do i have a problem if so what would be the prob and is this what makeing it miss thanks for your help
Old 09-29-2009, 03:03 PM   #5 (permalink)
I don't think those oil spots should be there at all.
Old 09-29-2009, 03:15 PM   #6 (permalink)
no am not but what could be the prob thank for your reply
Old 09-29-2009, 03:50 PM   #7 (permalink)
Sometimes a miss like that is due to one, or some of the injectors going bad.
Old 09-30-2009, 12:10 AM   #8 (permalink)
can any one tell me if its normal to have bit of oil in the air intake hose from the intrecoola two the throttoe body plzs
Old 09-30-2009, 02:10 AM   #9 (permalink)
carguy13's Avatar
Car: 91 BMW 320i
what i've been reading is people saying that the pcv valve was stuck open and needed to be replaced or the seals on the compressor side of the turbo was leaking oil...
you might want to replace the pcv valve first, it's cheap and real easy to do.
Old 09-30-2009, 03:46 AM   #10 (permalink)
Thanks a lot I have a look and let you all now what happens thanks agen for help
Old 09-30-2009, 06:43 AM   #11 (permalink)
Ave tell BMW for a pcv Valve is and thy don't no what it is
Is there another name for it
Car Revs up and down. SeVeN777 3-Series (E36) 6 01-25-2009 05:12 PM
2000 323i: missing bolts for joints inside secretstep 3-Series (E46, E90) 0 01-01-2009 02:12 PM
car hiccups at 1500 rpm's Lower_Level 3-Series (E36) 14 08-16-2008 12:48 PM
$1500 To Spend On A Project Car For My 18 Year Old lorenkp 3-Series (E21, E30) 11 03-01-2005 12:32 PM
Car Idling High Around 1000-1500 Rpms 325is1994 3-Series (E36) 3 12-26-2004 09:39 PM
