Mixing Gas - BMW Forum - BimmerWerkz.com
Old 05-01-2005, 01:07 PM   #1 (permalink)
afrochapin's Avatar
afrochapin is an unknown quantity at this point
Send a message via AIM to afrochapin
is it bad? does any one use 87 or 89 octane on their bmw?
<img src='http://www.imagehosting.us/himages/ihnp-206572.gif' border='0' alt='user posted image' />
afrochapin is offline   Reply With Quote
Old 05-01-2005, 02:25 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I believe the lowest you should go is 89... but check owners manual.
Yeah, even with 87 the engine can retard the timing, but it's not good.
Old 05-02-2005, 11:04 AM   #3 (permalink)
MichelVaillant is an unknown quantity at this point
[snapback]339837[/snapback]
I usually use Ethanol gazoline in my 525i. in canada, ethanol is mixed at 7% and helps cleans the engine(pistons, injectors, fuel filter) while driving and keeps the environment safer.
MV
MichelVaillant is offline   Reply With Quote
Old 05-02-2005, 12:18 PM   #4 (permalink)
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
Since filling up my 528 now cost more then my morgage payment, I switched to 87 and havn't noticed a thing. I even get the same gas milage. I dont know if this is a good thing, but Its better then paying $60.00 for a fill up
tacroteau is offline   Reply With Quote
Old 05-02-2005, 02:57 PM   #5 (permalink)
[snapback]340116[/snapback]
87 is too low for an octane level....you might hear some ping in the engine....don't forget, the lower your octane level, the more volatile it is and the more deposit of carbon you will have on your pistons...AND, regular gazoline is mixed with water...you don;t want that in your engine...I would opt for a higher octane for a BMW...heck the car is expensive as it is....
my $0.02
MV
Old 05-08-2005, 02:36 AM   #6 (permalink)
backindauk is an unknown quantity at this point
Im running 98 Octane.
I was running it on 91 for a while... well not me, my mum...
It runs much better now!
backindauk is offline   Reply With Quote
Old 05-08-2005, 07:19 AM   #7 (permalink)
Use what the owners manual says is required. Remeber that the octane rating on our US Pumps is in AKI (Anti Knock Index) and the European standard is RON (Research Octane Number). Example, 91 RON is equivalent to 87 AKI.
Old 05-08-2005, 11:08 AM   #8 (permalink)
rakeshp is an unknown quantity at this point
Well I also have a 528i and actually i usually put in 87 here in the US. The reason is not only beacuse of the gas prices but beacuse its not necessarily required for a higher octante. But dont get me wrong tho because i ALWAYS let the car run jsut about out of gas at some point (usually once or twice a month) and fill up the beaut with the highest octane level i can get. This helps keep the insides clean while saving me money! B)
rakeshp is offline   Reply With Quote
Old 05-08-2005, 12:45 PM   #9 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Originally posted by rakeshp+May 8 2005, 12:08 PM--><div class='quotetop'>QUOTE(rakeshp @ May 8 2005, 12:08 PM)</div><div class='quotemain'><!--QuoteBegin-tacroteau@May 2 2005, 01:18 PM
[snapback]342164[/snapback]
[/b][/quote]
Or you could just go midgrade all the time and still be spending the same amount of money...
Old 05-08-2005, 03:40 PM   #10 (permalink)
DEATH2000's Avatar
DEATH2000 is an unknown quantity at this point
[snapback]342118[/snapback]
were do u live? i live in canada and the most ive seen is 94 octane. ive been told no gas stations near me wanna go higher than that octane wise
I think the world's greatest irony would be if the Handi-Bus ran someone over and crippled them, thus forcing them to ride the Handi-Bus for the rest of their life.
&quot;Hey, it don't matter whether you win by an inch or a mile... Winning is winning&quot;
-Vin Diesel-
Proud Member: Traded a Mercedes for a BMW club
Proud Member: Im 16 and own a BMW and Mercedes-Benz club
DEATH2000 is offline   Reply With Quote
Old 05-08-2005, 04:45 PM   #11 (permalink)
filter27e is an unknown quantity at this point
Lol guys I hate to be mean, but octane ratings aren't that complicated, you should try looking it up sometime.
Ok let's begin:
1) Regular grade gasoline is not mixed with water. Water and gasoline won't mix, they're different weights and will just make a suspension. If you really think there's water in your gasoline, then pour it into a container that you can see in, and look for any seperation, layering, or beads of other liquids on the surface. Then don't use that gasoline if it has any of those
2) Lower octane gasoline does not produce more carbon buildup on the inside of your engine. Using too high of an octane actually will because the higher the octane number the slower the fuel burns.
3) The octane rating does not mean, well anything that I've seen mentioned on here so far. I recommend you go to howstuffworks.com for the best explanation on this one, but basically the octane rating is the percentage of the gasoline that is actually Octane (for example: 87% Octane / 13% Heptane). Oh and Octane handles compression better than heptane, but is more expensive. And yes I know obviously you can't have 115% Octane fuel, but the octane rating has matured into more of an equivelency chart... so anything that handles compression as well as the matched rating is ok. 115 octane fuel has lead added to it and therefore handles compression better than 100% octane fuel.
In short, use what your manual says. If you use too low octane than you get knocking because the fuel is exploding from compression before the sparkplug ignites. If you use too high of an octane rating then it burns too slow leaving you with unburnt fuel left in the cylinders.
1984 318i 5-spd that's not currently registered... project car.
1998 Subaru Legacy Sedan
1996 Nissan Maxima is the girlfriend's car that was glad to meet somebody who knew what &quot;routine maintenance&quot; was.
filter27e is offline   Reply With Quote
Old 05-08-2005, 05:33 PM   #12 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
gas is gas.
mixing doesnt matter...to get 89, they mix 87 and 91..
i would use what the manual says..but your car wont die because you are using something other than what the manual says...
the engineers that make engines realize that not all countries mix 91 or whatever fuel..so they make their engines able to run on whatever octane rating well.
brien4787 is offline   Reply With Quote
Old 05-08-2005, 11:56 PM   #13 (permalink)
68th gear and shifting
superdeadman's Avatar
Car: a lot of broken ones
superdeadman has a spectacular aura aboutsuperdeadman has a spectacular aura aboutsuperdeadman has a spectacular aura about
Send a message via AIM to superdeadman
if you got a bimmer, you expect to pay some $$$ for maintenance such as premium gas. So stop whining, and if you won't put at least 89 in your bimmer, just sell it because you're not worth it.
R.I.P. fast 6
"drive hard
keep it clean
superdeadman is offline   Reply With Quote
Old 05-09-2005, 08:29 AM   #14 (permalink)
tacroteau's Avatar
[snapback]342425[/snapback]
Old 05-09-2005, 08:33 AM   #15 (permalink)
tacroteau's Avatar
right... that must be it, Maybe we just cut corners WHEN WE CAN My BMW isnt my only toy I need to pay for.
I am running on grape juice 49 cents per gallon (exhaust smells good too)
Not to be an ass, but why not mix your gas with a box of pencils (they will blend together as well as gas with water) :nana
Slow to start - gas smell irish 3-Series (E21, E30) 2 11-01-2005 02:42 PM
Get a Free $250 Gas Card! jonson Wheels and Tires 0 10-17-2005 01:50 AM
Erratic Gas Guage misterervin 3-Series (E21, E30) 5 09-22-2005 08:20 AM
