misfire - BMW Forum - BimmerWerkz.com
Old 07-17-2004, 04:03 AM   #1 (permalink)
jib
jib is an unknown quantity at this point
Gents
I have a 93 520 (e34) (m50) and it has a misfire, Ive checked the plugs and they seem ok, what else should I check.
Jib
jib is offline   Reply With Quote
Old 07-17-2004, 10:45 AM   #2 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
not sure on your car does it have coils on top of plugs? I had a misfire on my 3 series 00 it was a bad coil replaced it and works fine now. 2cents worth used
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 07-17-2004, 12:45 PM   #3 (permalink)
ali-bumble is an unknown quantity at this point
Have you checked the HT leads and the distributer cap to make sure each cylinder is actually getting a spark? Is there any blue smoke from the exhaust cos that can be a sign that incorrect combustion is occuring within the block
ali-bumble is offline   Reply With Quote
Old 07-17-2004, 01:07 PM   #4 (permalink)
silverlea is an unknown quantity at this point
Fit a new set of leads and hopefully the problem will be fixed..........if not as others have mentioned move on to the coil and dizzy.Someone with a smart-scope would quickly identify where the probelm is for you,and would only take half an hour to do so.
Good Luck.
SILVERLEA.
silverlea is offline   Reply With Quote
Old 07-17-2004, 03:24 PM   #5 (permalink)
jib
Its the later type leads, not the usual dizzy cap etc, theres no smoke on start up.
jib
Ps what tyre presure should I be running on 205x60's
Cylinder 3 Misfire, Related To Air Mass Meter? jasonharlos 3-Series (E46, E90) 8 10-06-2009 10:13 AM
5 Series Engine Misfire jtroitino 5-Series (E12,E28, E34, E39, E60) 6 03-16-2006 04:19 PM
Misfire Detected Cyl #5 328I99E46 3-Series (E46, E90) 1 04-17-2005 10:22 PM
Misfire cylinder 1 Mrcapitan 3-Series (E36) 4 04-11-2004 03:28 PM
