Mass Air Flow Meter issue - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 08-17-2007, 04:57 PM Thread Starter
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
Well it finally happened. My MAF meter went south and the car won't stay running without me keeping constant pressure on the gas pedal. I checked the codes and it indicated it was indeed the MAF. In addition to the MAF going bad, a code for both 02 sensors (adaptation limit reached) appeared.
My plan is to get a new or slightly used MAF and replace the broken one and clear the codes. This is basically a plug and play deal. I tried cleaning it but the "cross hair: plastic piece inside the housing is broken so I should just replace the whole thing.
My question is this. IF the replacement MAF doesn't work, I am scheduled to take her into the shop on the 27th. Is there a way I can bypass the MAF just to get it to the shop to avoid a tow? I read somewhere you can unplug it?
Thanks all!
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline
post #2 of 9 (permalink) Old 08-17-2007, 06:33 PM
BMWJNKY's Avatar
BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute
There is no way to bypass the MAF and keep the car driveable. The O2 sensor code is from the MAF going bad and messing up the A/F mixture past where the O2 sensors can adjust it. If you replace the MAF and reset the codes and adaption values it should be ok as long as there are no other problems with the car.
BMWJNKY is offline
post #3 of 9 (permalink) Old 08-17-2007, 09:40 PM
Eric S.'s Avatar
Eric S. is on a distinguished road
It's a pain, but you really ought to just replace the MAF with a new one. Try getcoolparts.com. The MAFs fail often so getting a used one won't buy you much time....
<span style='color
urple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline
post #4 of 9 (permalink) Old 08-17-2007, 11:07 PM
CosmosBlack's Avatar
CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute
I dunno about the MAF sensor in the Bimmer, but when mine failed in the E39, the car won't even start.
In the 911, you can remove the MAF sensor and bypass it, and still drive the car. It's actually one of the procedures used to test if the MAF sensor is faulty, but there are certain simple steps to make to avoid a CEL when driving without the MAF sensor.
Good Luck.
2012 Porsche 911 GTS
2008 Ford F150 Foose Edition
2010 VW Touareg
Gone...2002 Porsche 911 C4S
Gone...2000 BMW 540i
Gone...1995 BMW 540i
CosmosBlack is offline
post #5 of 9 (permalink) Old 08-18-2007, 02:01 PM Thread Starter
ozarkmark's Avatar
I can reset the fault codes. Will this reset the adaptation limits for the sensors too or will I need to disconnect the battery for awhile?
post #6 of 9 (permalink) Old 08-18-2007, 02:05 PM Thread Starter
ozarkmark's Avatar
Thanks Eric. I suspect you are right on getting a new one. I'll check it out.
post #7 of 9 (permalink) Old 08-20-2007, 12:32 PM
BMWJNKY's Avatar
Disconnecting the battery does ok at resetting the adaptation values but the best way to do it is go into the computer with a GT1 or AutoLogic and reset it.
BMWJNKY is offline
post #8 of 9 (permalink) Old 08-20-2007, 08:11 PM Thread Starter
ozarkmark's Avatar
How much does a GT1 or Autologic cost vs. disconnecting th battery?
post #9 of 9 (permalink) Old 08-24-2007, 07:49 PM
BMWJNKY's Avatar
Do you want to band-aid it or fix it?
BMWJNKY is offline
Wanted: Air Mass Meter Boot topless_328 Looking For 1 05-06-2008 02:36 PM
318is Air Flow Meter newscam 3-Series (E36) 2 10-23-2006 03:27 PM
air flow meter e36chick 3-Series (E36) 11 08-25-2006 03:27 PM
mass air flow sensor peri 3-Series (E36) 2 02-15-2006 09:01 AM
fouled plugs / air flow meter artipticus 3-Series (E21, E30) 10 12-10-2005 06:57 PM
