Map code - BMW Forum - BimmerWerkz.com
Old 10-30-2007, 07:33 PM   #1 (permalink)
fastshivy's Avatar
Car: 1999 540i
fastshivy is on a distinguished road
Question Map code
My 1999 540 keeps setting an ses light. I pull the codes and it comes up as a map circuit board. I am assuming this is manifold absolute pressure. Does anyone have any ideas as to what could be causing this? Hose leaks? Any ideas? Just a bad circuit? Thanks for any help?
fastshivy is offline   Reply With Quote
Old 10-31-2007, 10:00 PM   #2 (permalink)
benzin's Avatar
Car: 2000 BMW 528i M conv
benzin is on a distinguished road
MAP sensor
most likely you need to replace the map sensor.That would be located in the intake manafold.
benzin is offline   Reply With Quote
Old 11-01-2007, 05:07 PM   #3 (permalink)
fastshivy's Avatar
Car: 1999 540i
The code according to Peake is.... Map controlled thermostat circuit/control. I am not sure this car has a map sensor. Could this be something more related to climate control?
Old 11-01-2007, 10:02 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
BMW does not use MAP sensors.
its for the engine coolant thermostat, om this car it is electronically controlled, thats why it can set an SES lamp.
Most likely just needs a new thermostat.
DT
Old 11-02-2007, 06:44 AM   #5 (permalink)
fastshivy's Avatar
Car: 1999 540i
Thanks DT-- The thermostat and water pump were replaced about 1 year ago. I also replaced the radiator and used genuine BMW coolant.The coolant I replaced looked perfect no rust etc. I have never had an issue with overheating etc. It also sets a code for safety concept monitoring....are the two tied together? Thanks again for getting me on the right path
Old 11-07-2007, 01:13 PM   #6 (permalink)
fastshivy's Avatar
Car: 1999 540i
Knock sensor
Well, now I am getting a consistent knock sensor code on cylinder 3-4 I have not replaced the thermostat yet, so the code comes on the same time as the MAP code. I clear them and they are back on in about 5 miles. Are these related? Does the intake manifold have to come off to reach the knock sensor?
Old 11-08-2007, 03:56 PM   #7 (permalink)
fastshivy's Avatar
Car: 1999 540i
Lightbulb
un be friggin believable I pulled the intake manifold today and a rat or some kind of varmit had crawled under my intake. The knock sensor wire was chewed in half and there was nesting material every where! This car gets driven almost daily so that must be one mean critter. Replaced the electronic thermostat as well. Bimmer forum had a good explanation as to how they work. Makes sense now. Well I hope the bastard freezes tonight!!!!!!!!!!!
Old 11-13-2007, 01:25 AM   #8 (permalink)
Moderator
Dirty_Tool's Avatar
damned Rats... I see a lot of rat damage on wires, BMW must dip their wiring harnesses in syrup before installing
DT
Old 11-13-2007, 12:00 PM   #9 (permalink)
fastshivy's Avatar
Car: 1999 540i
Ha Ha that is funny. I just put it back together and it runs great, no more codes! Coated the wires with arsenic and peanut butter..Ha ha
E30 Anti-theft Radio Code aaronhoy 3-Series (E21, E30) 4 06-08-2009 11:40 AM
Odd Radio Code Trouble 24valve 3-Series (E36) 5 11-25-2006 06:42 PM
Dwa/ews Input Peake Fault Code? jday 5-Series (E12,E28, E34, E39, E60) 8 02-04-2005 09:19 AM
Asking For Code jshearer Audio and Electronics 1 12-18-2004 08:28 PM
stereo/radio anti-theft code xristo 3-Series (E21, E30) 3 03-02-2004 04:18 PM
