Main Beam problem - BMW Forum - BimmerWerkz.com
Old 06-30-2007, 05:52 AM   #1 (permalink)
Geordiedownsouth is on a distinguished road
Main Beam problem
Hi everyone,
My first post so not sure if this is the correct place.
My 528i has developed a roblem with the offside headlamp.Bulbs are ok but the mainbeam doesnt work. Any help would be appreciated.
Cheers Ron.
Geordiedownsouth is offline   Reply With Quote
Old 06-30-2007, 12:30 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
have you checked your fuses?
Old 06-30-2007, 03:58 PM   #3 (permalink)
Hi saltshaker,
Is there a fuse for each headlight?
Cheers Ron.
Old 06-30-2007, 11:03 PM   #4 (permalink)
cnn
cnn is on a distinguished road
Lcm
You may have a problem with the LCM.
See this thread:
Group buy for LCM Repair Part Infineon BTS426L1??? - bimmerfest - BMW Forums
Usually when the Infineon BTS426L1 chips fail, they fail closed which means HIGH BEAM ON all the time, even with key off.
You chips might have failed OPEN, which means regardless of what you do, the HIGH BEAM is OFF.
I still have the Infineon chips, about 6 pairs remaining. If you are ineterested. PM me as "cn90" at bimmerfest.com.
I don't come here very often at all.
cnn
cnn is offline   Reply With Quote
Old 07-01-2007, 10:30 AM   #5 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Hey CNN, perhaps you can explain what happened to my LCM on my last e34.
When I first got the car, the wiring harnesses for the fog lights were cut/broken. So I wandered down to advanced auto and picked up a set of new ones and hooked them up. I plugged in my new fog lights and replaced the housings.
Now the wierd stuff started happening. The first time I started the car, it immediatley said my fog lights were out. However... They were on. I flicked on my driving lights and they worked as well. Along with high beams.
However when I flicked my high beams on, my fog lights remained on. I know doing such for on road use is illegal, however. I'd like to know if there is an easy way to "recreate" this problem.
d3ity is offline   Reply With Quote
Old 07-01-2007, 06:00 PM   #6 (permalink)
cnn
Chip
Hi,
I don't know about E34 but being built at the same time as the E39, the technology is prob very similar.
It might have been the Infineon chips I talked a bout.
I have 6 pairs left.
I do not come here often, I am more at bimmerfest (username "cn90")
Old 07-01-2007, 06:49 PM   #7 (permalink)
teh Canuck....eh
PhatCat's Avatar
Car: '86 E30, baby! '05 Legacy 2.5GT Ltd
PhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond repute
Send a message via MSN to PhatCat
Welcome Ron...I don't have any answeres to your issue, but I wanted to welcome you to Bimmerwerkz!
All great things are simple, and many can be expressed in single words: freedom, justice, honor, duty, mercy, hope.
Sir Winston Churchill
PhatCat is offline   Reply With Quote
Old 07-02-2007, 05:15 AM   #8 (permalink)
Hi,
Thanks for the welcome.
Ron
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
Headlight problem: City lights don't work (low and high beam do) KILOCHARLIE 3-Series (E36) 4 09-21-2005 01:33 AM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
Fog Light Modification E39 ViewMaster Bimmer Talk/Motorsports Talk 1 10-25-2003 11:09 PM
