m62 timing - BMW Forum - BimmerWerkz.com
Old 08-25-2008, 03:59 PM   #1 (permalink)
scott41695 is an unknown quantity at this point
m62 timing
I have pulled a 4.4l. out of a 97 740il. It was in perfect running order. When I got the engine out I removed the top timing covers to check for wear on the tensioners. Now when I try to turn the motor by hand, it stops at about 45 degrees rotation, in iether direction. I am thinking it jumped timing and is being heid up by an open valve. Cav someone please shed some light on this for me!
scott41695 is offline   Reply With Quote
Old 08-25-2008, 09:12 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
are u turning the engine over with the upper timing covers removed? did u remove the sprockets and secondary chains or just the main tensioner?
DT
Old 08-26-2008, 08:56 AM   #3 (permalink)
yes, both upper covers were removed and the tensioner was realeased
Old 08-26-2008, 11:53 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
you can not turn over the engine with the tensioner out unless you support the rail manually by giving it tension. If you try the chain will bind up.
DT
Quality M62 engine b-tuning 5-Series (E12,E28, E34, E39, E60) 17 07-12-2009 04:25 AM
740i/M62/Auto (1997) - Engine Idle and ASC problems BigBazza 1,6,7,8 - Series and Mini Cooper 0 01-19-2006 04:19 PM
M62 Dead Engine Tatch 5-Series (E12,E28, E34, E39, E60) 1 01-05-2005 04:54 PM
02:00 E39 M62 Dme 26/26 e28m30 5-Series (E12,E28, E34, E39, E60) 0 11-02-2004 09:46 PM
M62 engine swap eye 5-Series (E12,E28, E34, E39, E60) 2 05-29-2004 05:06 PM
