M54 Coolant Temp Sensor in Lower Rad Hose.. - BMW Forum - BimmerWerkz.com
Old 10-12-2008, 05:05 PM   #1 (permalink)
Car: 2001 Black 530i
Surfer681 is on a distinguished road
Post M54 Coolant Temp Sensor in Lower Rad Hose..
Need some advice. I recently replaced just about all my cooling parts: Low/Up hoses, Watermpump, Thermostat, Radiator, and both belts. Bled the system and started her up...No leaks! Hour later, it is leaking from the Coolant Temp Sensor in lower hose. It's the old sensor, you think the rubber 'O' ring shrunk or...?? Bought all my parts from Autohausaz.com. Thanks in advance!
Surfer681 is offline   Reply With Quote
Old 10-12-2008, 09:43 PM   #2 (permalink)
W00T
Numark318i's Avatar
im sure the seal shrunk.
even if it didnt, i would replace it, because it will more then likely go out, just like mine.
Old 10-13-2008, 07:44 PM   #3 (permalink)
Thanks for the reply. Think I will repalce with new sensor and not have to worry about it.
Coolant temp sensor?culprit? bimmerguy82 3-Series (E36) 7 04-21-2007 10:36 AM
Replacing A Coolant Hose BYOCOM 3-Series (E36) 3 04-21-2005 03:55 AM
How To Tell If Your 540's Rad/hose Is Original Eric S. 5-Series (E12,E28, E34, E39, E60) 2 02-04-2005 10:50 PM
Coolant Hose And Brake Pop? silver328is 3-Series (E36) 5 10-01-2004 06:36 PM
Coolant Hose Diagram? M5power 5-Series (E12,E28, E34, E39, E60) 0 03-21-2004 11:36 AM
