M50 glitch/fault/problem - BMW Forum - BimmerWerkz.com
Old 10-24-2008, 12:28 AM   #1 (permalink)
Ricbmw is on a distinguished road
Hi BMW owners, I have now my first BMW e34 M50 ( no vanos) and it decided to give me some grief. Hitting the net and reading a lot of faults with this model, I have followed all the quick checks I can. Fuel side is fine with every thing in the chain working, relays, pump, pressure. I did the fuid spray in the intake and still no start. (turns over but will not fire). Took off a coil pack and did the screwdriver test, no spark. Following common advice on the the net I changed the CPS out with no result. Put both CPS units on the multi meter and get a reading of 520 ohm. I have full electrics on the car but between this system and the plugs theres a problem. I can only point the finger at the ECU (0 261 200 403). If I reset the computer and still have this problem am I on the right path?
Regards to those that can help. Here it is unburnt, but soon maybe...
Ric
Ricbmw is offline   Reply With Quote
Old 10-24-2008, 12:56 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Crankshaft sensor or camshaft sensor
Old 10-24-2008, 01:29 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Download the Bentley service manual pinned at the top of the 5 series subforum. It's a great troubleshooting tool.
Old 10-25-2008, 02:42 AM   #4 (permalink)
Hi Torque, Did that a few days ago and yes it's a good guide. Still have my problem. info not going into the ECU or ECU not letting it out. Have fitted a new Crank sensor with no result. New battery, new starter motor, new fuel lines, new plugs, new relay's, new hoses, new rad core, new "steel" water pump.. Will battle on.....
Regards
Old 10-25-2008, 08:30 AM   #5 (permalink)
Question
If anyone knows, the Bentley refers to testing the crank sensor and getting 540 ohms for the m20/m30 sensor. The sensor supllied by the dealer gives this reading as the old one does as well. Bentley states for the m50 is much higher, is this critical?
Regards Ric
To m50 Or Not To M50????? Ineed Your 2 cents and maybe some tricks AlpineSixAndSeven 3-Series (E21, E30) 18 12-12-2006 11:54 PM
M50 problem? darren_rice 5-Series (E12,E28, E34, E39, E60) 1 11-12-2006 06:41 PM
Small glitch I noticed BMWJNKY Bimmerwerkz.com Site Help 2 09-08-2005 07:15 PM
Weird sunroof glitch asiangear 3-Series (E46, E90) 0 10-02-2003 11:44 PM
