M30 Engine in a 528e - BMW Forum - BimmerWerkz.com
Old 01-03-2004, 05:18 PM   #1 (permalink)
Wurzig-Drei's Avatar
Wurzig-Drei is an unknown quantity at this point
Send a message via AIM to Wurzig-Drei
Does anyone know if i could fit a 3.5l m30 engine into my 1985 528e? Right now it has a 2.7l m20 eingine. I was just toying with the idea and was wondering if its even worth trying.
Under construction
Wurzig-Drei is offline   Reply With Quote
Old 01-03-2004, 06:33 PM   #2 (permalink)
e36_m3_Turbo's Avatar
umm ur better off dropping a s52 3.2l in ur e28 with some mods..
No longer red.
Old 01-03-2004, 11:48 PM   #3 (permalink)
Thats gonna cost me a lot more. Are you talking about the S52 engine with 321 hp?
Under construction
Old 01-04-2004, 01:03 AM   #4 (permalink)
no...the s52 from the U.S. Spec m3. 240hp
No longer red.
Old 01-04-2004, 03:05 PM   #5 (permalink)
Would i need a new tranny. And if i wanted to would the m30 fit or would it be near impossible. I was thinking of rebuilding a m30 engine, so i could buy it cheaper. But finding a s52 engine to rebuild is going to be more difficult.
Under construction
Old 01-08-2004, 12:08 AM   #6 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
What you are trying to do would cost a lot. Two entirely different engines.
2.7l=small block. 3.2/3.4l=big block.
The engine will fit in the but the motor mounts and mounting posotions are different. I think the trannys won't bolt up either. I am not sure if the drive shafts are the same.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Old 01-08-2004, 01:44 PM   #7 (permalink)
Do you think it is possible at all to put the m30 engine in. Do you think its possible to swap the engine at all. Like say if i were to put different mounts in. Or am i just fighting a lost cause.
Under construction
Old 01-09-2004, 11:42 PM   #8 (permalink)
E28boi's Avatar
You can do anything if you have the money.
86 535i
99 Passat V6
'88 528e Engine Replacement JPau 5-Series (E12,E28, E34, E39, E60) 3 03-15-2005 12:34 PM
Engine Rebuild For A 1988 528e freshfish 5-Series (E12,E28, E34, E39, E60) 4 10-18-2004 11:22 PM
