Lowering A 525i. - BMW Forum - BimmerWerkz.com
Old 03-12-2005, 07:46 PM   #1 (permalink)
brians15 is an unknown quantity at this point
I have a 1993 525i w/ stock suspension and would like to lower the car. I have looked at the spring kits. How hard are they to install? WHat springs work best for street use? dont want a harsh ride. The front ride height is really the only part i want to lower but would i still have to change all 4 springs? Thanks.
brians15 is offline   Reply With Quote
Old 03-12-2005, 07:48 PM   #2 (permalink)
CiscoKid's Avatar
you have to replace all of the springs.
It is very easy to install as long as you have jackstands, floor jacks and spring compressors
Old 03-15-2005, 03:07 AM   #3 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
NO! DON'T DO IT!! Okay, I know that my comment there will hold no water. So, here's another way to look at it. Lowering your car will not raise your value, which is important whether you want to sell it or not. Put the money towards something more noticeable (dings, scratches, etc) or save it in case something happens to it. If you can, post a pic. Of all the attractive things to do to your car, lowering it should be the last on your list. AND, it will look horrible if the whole thing doesn't tie together (i.e. lowered but you could use new wheels/tires/tink...)
Okay, and since this hasn't been cleared up for me ever, how much does getting that done cost? Why (exactly) does a lower car look better? Doesn't it bug you that ricer's do that kind of stuff? Aren't you happy with your car the way it is?
I know those will rub people the wrong way, but i don't understand and it bugs me that people think SOMETHING needs to be altered.
BeachBunny is offline   Reply With Quote
Old 03-16-2005, 04:16 PM   #4 (permalink)
Originally posted by BeachBunny@Mar 15 2005, 03:07 AM
NO! DON'T DO IT!! Okay, I know that my comment there will hold no water. So, here's another way to look at it. Lowering your car will not raise your value, which is important whether you want to sell it or not. Put the money towards something more noticeable (dings, scratches, etc) or save it in case something happens to it.* If you can, post a pic. Of all the attractive things to do to your car, lowering it should be the last on your list. AND, it will look horrible if the whole thing doesn't tie together (i.e. lowered but you could use new wheels/tires/tink...)
[snapback]311761[/snapback]
you were right - it rubbed me the wrong way... basically because of the whole "doesn't it bug you that ricer's do it?" that's pure ignorance. I'm sorry but it is. Lowering a vehicle isn't just for looks and BMWs benefit from it when it's done properly!! A BMW is NOT perfect!!
btw it makes the car look better because the wheel well gap is usually thought of as "unsightly"
Also - if lowering were bad, stupid, dumb, whatever you may think - BMW would NOT offer a sport package which lowers the car 3/4" !!! Usually to lower a car properly with springs, shocks and installation, you shoul dlook to spend around $1000 - $1200 for good stuff.
As for the original poster - I have H&R springs + Bilstein shocks and love it, but it may be a little too rough for you - I recommend Koni's and Eibach springs. That would be a little softer and more adjustable for you - without lacking much at all in the performance department in comparison to the H&Rs.
Where are you located? If you're close by I could take you for a ride in my 525 with H&Rs..
Old 03-20-2005, 09:47 AM   #5 (permalink)
Originally posted by sp0rky+Mar 16 2005, 04:16 PM--><div class='quotetop'>QUOTE(sp0rky @ Mar 16 2005, 04:16 PM)</div><div class='quotemain'><!--QuoteBegin-BeachBunny@Mar 15 2005, 03:07 AM
I am located in Atlanta, do i have to get new shocks also?
[snapback]312926[/snapback]
[/b][/quote]
Old 03-21-2005, 05:43 PM   #6 (permalink)
You really SHOULD get new shocks. Koni adjustables and bilstein sports are the most popular. I feel that you may be happier with the Koni adjustables, as you can tune them for a little bit softer ride, but they are very expensive. 4 Koni adjustables, 4 Eibach springs and installation may be very close to $1100.
The problem with just using your stock shocks is that I garauntee they are blown by now, or if you just replace them with standard shocks, not ones made for "sport" applications, the springs will be too stiff for the shock, and the shock will not keep the ride "tight and controlled" - over large bumps, it would just bounce and sway, very similar to an old car with blown shocks.
A lot of people do it the cheap way and just swap springs - roughly 280 for springs and 300 for installation, but might as well do the job right and get the shocks too. a shop shouldnt charge any extra labor anyway.
good luck
Old 03-21-2005, 09:55 PM   #7 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
shox.com has kits for e34s... koni adjustables with eibach should run you around 800 bux if i remember right. check the prices.
Old 03-23-2005, 09:46 AM   #8 (permalink)
[snapback]316100[/snapback]
+300 to install and we're right around that 1100 i quoted earlier.
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 05:39 PM
325 lowering springs on a 318 jamspeed 3-Series (E21, E30) 2 09-26-2005 10:12 PM
E28 - Is The Radiator The Same On The 525i & 528i? roscoa1 5-Series (E12,E28, E34, E39, E60) 0 01-08-2005 02:28 PM
Lowering Springs sabbath130 3-Series (E36) 12 11-25-2004 02:32 PM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 09:51 PM
