| Lower steering shaft The universal joint on the lower steering shaft is partially seized, the effect is intermittent stiffness in the steering (I've pretty much eliminated other possible causes). Is it possible to remove the lower shaft without removing the steering wheel and disassembling the whole column? Bentley is not helpful and my searches haven't turned up anything.
Appreciate some help |
