Loud Noise From Acceleration And Nav Misbehaviour - BMW Forum - BimmerWerkz.com
Old 12-13-2004, 03:52 AM   #1 (permalink)
iconnx is an unknown quantity at this point
Hi guys...
Besides the climate confusion I am having, I have another 2 issues.
The first is relating to when I accelerate from standstill, sometimes, I get a loud fan type noise (a WHOOSH if you must) and sometimes I dont...Anyone have any ideas? Also, the Nav unit seems to go off map when I am using it to route a destination and go to radio, or the computer all on its own.Chooses when it gives me the arrow guidance or screen guidance all on its own... I would appreciate any help... TIA
Cheers
Ram
PS> Update
I beleive the noise I am hearing is the clutched fan engaging intermittently... Isnt it supposed to only engage at higher rpm's or is it normal for it to do this? I just heard it now for a couple of seconds upon starting the car and I am wondering if it has a faulty clutch on it....
iconnx is offline   Reply With Quote
Old 12-13-2004, 06:16 AM   #2 (permalink)
cassidym is an unknown quantity at this point
Originally posted by iconnx@Dec 13 2004, 03:52 AM
Hi guys...
Cheers
Ram
PS> Update
[snapback]248974[/snapback]
iconnx, what model and year 5er have you got?
I was confused at first with the Nav system and arrow direction. Then, contrary to my usual behavior, I actually read the instructions and learned how to activate the arrow guidance. Once you've entered the address and clicked on Start Guidance, pull back on the controller. Highlight 'Map Direction of Travel' or 'Map Facing North' and press the controller. This brings up the map in the main screen. Then, push the controller right. This highlights the auxillary screen also known as the Assisatnce Window. Press the controller down and, from the menu that appears, select "Map, Arrow display"
Other choices in the Assistance Widow are "Map Direction of Travel", "Map Facing North", "Current Position" and Blank Screen. Thus, you can have this screen dispaly either the map or arrow guidance when you are using the Nav but want to use the main screen to switch over to Radio or some other feature.
cassidym is offline   Reply With Quote
Old 12-13-2004, 07:47 AM   #3 (permalink)
Originally posted by cassidym+Dec 13 2004, 11:16 PM--><div class='quotetop'>QUOTE(cassidym @ Dec 13 2004, 11:16 PM)</div><div class='quotemain'><!--QuoteBegin-iconnx@Dec 13 2004, 03:52 AM
Hi guys...
Cheers
Ram
PS> Update
[snapback]248991[/snapback]
[/b][/quote]
Thanks a lot mate. That makes sense... My car is a 2000 540iA Sport BTW. I didnt realise that you could pull on the knob...I was under the impression that it was push only.... Goes to show that sometimes you just gotta fiddle wth your knob! :lol:
Any ideas on the rest of the issues I seem to be having anyone?
Cheers
Old 12-13-2004, 03:35 PM   #4 (permalink)
You can't pull up on the controller but you can push it towards the rear of the car. Doing that after you enter the address in the NAV screen will highlight the Map Choice window. Push it towards the passenger seat and you highlight the Assist Window. This assumes your BMW is left hand drive.
