losing water - BMW Forum - BimmerWerkz.com
Old 07-21-2010, 10:40 AM   #1 (permalink)
snake0180 is on a distinguished road
losing water
i have a e34 520i v12 straight 6 bmw
after 30-50 miles i lose about 500ml of water.i have fitted a new thermostat and a new viscous fan{both were faulty}now the temp don't go above the quarter before the fan cuts in.there is no visable leak inside or out.it is parked undercover and everything is bone dry.the oil is clear of water on the dipstick and cap.doe's anybody have any idea's where the water's going.
snake0180 is offline   Reply With Quote
Old 07-21-2010, 10:52 AM   #2 (permalink)
You may have to pressure test the cooling system to find the leak. Welcome!
Old 07-21-2010, 11:13 AM   #3 (permalink)
reply
i forgot to mention it has already been pressure tested and no loss of pressure or water
Old 07-21-2010, 11:52 AM   #4 (permalink)
Do you have any reason to suspect a small head gasket leak?
Old 07-22-2010, 03:34 AM   #5 (permalink)
head gasket
there's no water in the oil.i would of thought if it was the head gasket it would have lost pressure on the pressure test
Old 07-22-2010, 10:08 AM   #6 (permalink)
Maybe there's an issue with the expansion reserve tank in the engine bay.
Old 07-26-2010, 08:51 AM   #7 (permalink)
Smile sorted it
i did another pressure test but left it a lot longer and it dropped slightly but still no sign of water anywhere.so i bought some k-seal which is a coolant leak repair,which repairs:head gaskets,blocks,anything metal.it works with antifreeze so theres no messing about draining the system.just pour it in and go,it worked a treat,no more leak.yippee.
Old 07-26-2010, 09:41 AM   #8 (permalink)
Very cool!
losing water dudehog 3-Series (E36) 12 01-04-2010 05:08 PM
1999 e46 318 losing water CR+DR-Ltd 3-Series (E46, E90) 19 11-24-2009 08:12 AM
Losing coolant georgianarock 3-Series (E36) 1 04-14-2008 09:59 AM
E38 98 or under water pump for non water cooled alternators brand new AlpineSixAndSeven OEM Parts 0 10-12-2007 03:58 PM
540 - Water Leak - Radiator? Exp Tank? Water Pump? windarra 5-Series (E12,E28, E34, E39, E60) 2 06-09-2006 10:13 PM
