losing power / Air flow Noise when accelerating - BMW Forum - BimmerWerkz.com
Old 07-25-2004, 12:13 PM   #1 (permalink)
Gaizeh is an unknown quantity at this point
Has anyone had this problem were the car does not pick up properly ( feels like it loses power ) when you step on the gas and at the same time you hear some kind of pinging / air flow noise from the engine. The engine temp also goes up after a while !!!!!!
Gaizeh is offline   Reply With Quote
Old 07-26-2004, 11:31 AM   #2 (permalink)
isosceles is an unknown quantity at this point
That sounds similar to a problem I had with another car. The cause turned out to be a clogged catalytic converter.
isosceles is offline   Reply With Quote
Old 08-23-2004, 05:20 PM   #3 (permalink)
dreamer_bimmer is an unknown quantity at this point
Hi there. I had a similar problem with my 1990 525i, the car started fine but as I went along the road the engine started to struggle and the revs would not go above 2000rpm. I pulled over and tried to warm the engine up a little by revving a little but it was still struggling, as though it was going to cut out.
After about 5 mins it started acting normally and I continued without any more problems. I didnt hear any unusual noices though.
I saw one reply to a similar problem saying that the inlet manifold may be cracked
Any ideas?
dreamer_bimmer is offline   Reply With Quote
Old 08-29-2004, 09:43 AM   #4 (permalink)
AngelMoo is an unknown quantity at this point
1983 528i wouldn't accelerate as good as usual and started sounding a lot louder than usual, mechanic said it sounded like a truck. The muffler had to be replaced.
AngelMoo is offline   Reply With Quote
Old 08-29-2004, 11:44 PM   #5 (permalink)
billB's Avatar
If converter is ok check your hoses for maniflod leaks that hissing noise may well be air leak under the manifold mine just recovered from that one
Old 08-31-2004, 08:12 PM   #6 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Same problem on the 6 series. Try this
You see all those hoses on your air intake. Replace them. 50 bucks and an hour.
Vaccum lines...get those too. always helps preformance to have fresh ones.
Check for any cracks in your air intake. Check your air filter too.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Power Steering Noise supark 3-Series (E36) 4 11-02-2004 08:45 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
losing power / Air flow Noise when accelerating Gaizeh 5-Series (E12,E28, E34, E39, E60) 0 07-25-2004 12:12 PM
