locked out - BMW Forum - BimmerWerkz.com
Old 12-30-2008, 01:58 AM   #1 (permalink)
wade81 is on a distinguished road
locked out
hi every one. ok i have a 90 535i i went to costa rica a few weeks ago and left my car out side locked. its bout -30 out and i cant get into it. ive tried holding the door handles up and unlocking it but its not working. does any one have any suggestions on how i can get into my car?
wade81 is offline   Reply With Quote
Old 12-30-2008, 04:49 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
So is the batt flat or is it just iced up ?
Old 12-30-2008, 08:07 AM   #3 (permalink)
vincentmb615's Avatar
Car: 94 325i two toned full body kit
vincentmb615 is on a distinguished road
Send a message via AIM to vincentmb615
if batt is dead it should still open hard put de icer in the lock and turn it should open if the seals frozen you might have to pry it open while holding the handle
[94 325i two toned
vincentmb615 is offline   Reply With Quote
Old 12-30-2008, 09:14 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Try hitting the windshield on the driver's lower side with your fist. I have heard this unlocks the doors in case of an accident. I'm not kidding!
Good luck,
LOS
Old 12-30-2008, 09:37 AM   #5 (permalink)
i think the batt is dead, im not going to hit the window cause well the just doesnt make any sence, but i wi ll try the de icer in the lock.
Old 12-30-2008, 09:39 AM   #6 (permalink)
Good luck,
LOS
Would you wanna be the first to test this on your car?
Old 12-30-2008, 10:25 AM   #7 (permalink)
marti5's Avatar
Is your batt in the boot, if so you should be able to unlock boot manually then you can put some jump leads on your batt this should give enough power to open the doors via remote.
Old 12-30-2008, 03:07 PM   #8 (permalink)
LOS
LOS's Avatar
I'm not kidding, he said it worked for him. He did it on an 8 series model though and the engine was running with the doors locked. I read it on another forum.
I thought he could try it, had nothing to lose anyway. It was just a bump on the windshield, It's not like he took a hammer...
Just trying to help!
LOS
Old 12-30-2008, 03:17 PM   #9 (permalink)
LOS
Isn't most likely that whatever happened was more of a chance fluke than a consistent, expectable result?
Old 12-30-2008, 03:33 PM   #10 (permalink)
LOS
LOS's Avatar
I don't think it was a fluke. I'm trying to find the link in the ROADFLY forum but I can't find it. Like I said, his car was 8 series with the engine running and the doors locked.
This other member, said that in case of an accident, all doors unlock themselves during impact. I think it's a nice feature, I sure don't want to be locked in if the car catches fire.
So he suggested the windshield "bump" on the driver's side since there is an impact sensor in that area.
LOS
Old 12-30-2008, 03:43 PM   #11 (permalink)
I would think an unlock on impact switch would be something based on a sudden change in motion, based on the conservation of momentum.
Old 12-30-2008, 03:56 PM   #12 (permalink)
LOS
LOS's Avatar
Good point!
I would still try it if I'm locked out though... ha ha
LOS
Old 12-31-2008, 10:18 AM   #13 (permalink)
Moderator
Dirty_Tool's Avatar
the "bump" trick only works if the key is in the on position and the battery is Ok. if he has a dead battery and is locked out this wont work. Also, its not at the windshield on a 5 series. you need to jack the car up with a jack and get under it and hit the area directly below the rear seat. This is where the crash sensor is located.
Sounds like he has a dead battery and has already tried using the correct method which is to lift up on the handle before turning the lock. Problem is now that these cars are getting older a lot of times the lock cylinders are worn out and so this safety feature no longer works. Worst case scenario you can break into the engine compartment using a long skinny flat blade screwdriver to manipulate the hood latch. once under the hood you can use a jump box or another car with jumper cables to energize the car and then the key should work in the doors. no need to use the "bump" method if you have the key.
DT
Old 01-02-2009, 12:22 AM   #14 (permalink)
ok its getting colder and colder out, so im going to wait til the spring and get into her then. thanks every one for the helpfull suggestions
Seatbelts Locked BIMMER19 3-Series (E36) 1 06-27-2008 09:11 AM
Locked Out! sammy_l18 5-Series (E12,E28, E34, E39, E60) 3 05-05-2005 10:05 PM
Ignition Locked tcompton2 3-Series (E36) 2 03-30-2005 12:22 AM
Locked out pghbimmer 5-Series (E12,E28, E34, E39, E60) 18 08-26-2004 02:07 PM
LOCKED OUT!! rocco 3-Series (E36) 21 12-08-2003 01:51 AM
