Lighting Question - BMW Forum - BimmerWerkz.com
post #1 of 13 (permalink) Old 05-25-2005, 03:07 PM Thread Starter
Scotty Dangles is an unknown quantity at this point
Hey Guys,
I'm in the preliminary process of upgrading my headlights on my 1994 530. I want to upgrade to an HID lighting system. So far I have had a lot of help from Sporky (thank you Sporky, you rock), and I have been doing a lot of research on my own. But today I think I may have come across some good news to all of us E34 owners...!
I'm sure most of you know that the in 1991 BMW introduced Xenon lights on their 7 series models. Well after doing some research it appears that the low beam part number on the 750 series BMW is the same as the low beam assembly on our trusty E34's! (I looked it up)
So this begs the question: Since the 750 had Xenon lights, can our stock lighting assemblies be fitted with HID bulbs without having to change the projector...! I have a feeling Sporky mentioned something on this...before to me! I did notice that my stock projectors have an almost exact pattern as newer HID Projectors....
Any thoughts or experiences on this???
Scotty Dangles is offline
post #2 of 13 (permalink) Old 05-25-2005, 04:45 PM
While the 750s projectors are the same, the XENON equipped ones were actually different. (not all 750s had xenon even though it was introduced on that car) Check out www.realoem.com for proper part numbers, etc.
Also note that the e32 750 had xenon in the US in 1994, so look it up in that year.
They have a seperate section for bosch and hella xenon units. Even the picture of the projectors look different. It's all about optics.
But like I said, upgrading to xenon lights, you'll be more than happy with putting them in the stock projectors. The upgrade is still incredible. And remember, even if you got the original 750 xenon projectors, you'd still be better off with newer ones because the technology of those things is rapidly changing. There are so many choices... more curve, fresnel vs. clear, etc etc etc.
sp0rky is offline
post #3 of 13 (permalink) Old 05-25-2005, 10:43 PM Thread Starter
[snapback]347812[/snapback]
I knew you would jump on this thread! :P I tried looking for you on MSN, but you weren't online!
Alright so how about this, I'll do the upgrade in steps...I'll start off with buying the Ballasts, wires and bulbs. If at this point if I'm still dissatisfied...I'll do the projector swap! Would that work?? Also do you have any companies to recommend of the top of your head to do the retrofit???
Question for you...what colour temp should I get? I was thinking 5000K or 6000K? Will there be much of a difference?
Ayight Peace, I'm off to bed!
Sporky you are my lighting hero! hahaha
post #4 of 13 (permalink) Old 05-26-2005, 12:26 AM
You WILL be satisfied since you have halogens. I think you'd be satisfied without even having projectors at all. lol :-p
Sounds like a plan...
Color temp... 6000k is less light, more blue... 4300k has the most light output. 5000k IS 4300k with a blue tint.(I always stick w/ith 4300k, because it is OEM and looks not too blue) You choose
sp0rky is offline
post #5 of 13 (permalink) Old 05-26-2005, 04:28 AM
k2c69n's Avatar
k2c69n is an unknown quantity at this point
Here is a Headlight QUestion?
I have silverstar's in my headlamps right now, and i like them but they dont last long, my fog has already burned out. I dont feel like replacing them every couple of months.
What other bulbs are out there that has a longer shelf life. I wasnt looking into changing out the whole headlight setup up, just doing something under $100..
Thanks
*If your not living on the edge your taking up too much space*
'98 328is
k2c69n is offline
post #6 of 13 (permalink) Old 05-26-2005, 07:29 AM Thread Starter
Thanks
[snapback]347944[/snapback]
I bought the shining wizardst and I really like them...but I want HID...
Don't the Silverstars have a one year warranty??? They shouldn't be burning out so quickly...I had a pair in my Avenger??
post #7 of 13 (permalink) Old 05-26-2005, 07:33 AM Thread Starter
[snapback]347912[/snapback]
LOL! Alright so I'll be satisfied then just doing what I proposed above...!
I think i will get the 5000K, thats what my current bulb colour, it looks pretty...in HID it would be kick ass!
Now to pick the best package...any ideas on how much I should spend on this package???
post #8 of 13 (permalink) Old 05-26-2005, 07:45 AM
k2c69n's Avatar
Originally posted by Scotty Dangles+May 26 2005, 06:29 AM--><div class='quotetop'>QUOTE(Scotty Dangles @ May 26 2005, 06:29 AM)</div><div class='quotemain'><!--QuoteBegin-k2c69n@May 26 2005, 04:28 AM
I have silverstar's in my headlamps right now, and i like them but they dont last long, my fog has already burned out.* I dont feel like replacing them every couple of months.
What other bulbs are out there that has a longer shelf life.* I wasnt looking into changing out the whole headlight setup up, just doing something under $100..
Thanks
[snapback]347954[/snapback]
[/b][/quote]
I will definately check that out when i get home from work. A year warranty would be sweet.
'98 328is
k2c69n is offline
post #9 of 13 (permalink) Old 05-26-2005, 10:07 AM Thread Starter
Originally posted by k2c69n+May 26 2005, 07:45 AM--><div class='quotetop'>QUOTE(k2c69n @ May 26 2005, 07:45 AM)</div><div class='quotemain'>
Thanks
[snapback]347957[/snapback]
[/b][/quote]
Do it...I bought mine at Autoparts Source and well after a couple of months I lost one and they replaced it for free....I had the receipt....
post #10 of 13 (permalink) Old 05-26-2005, 01:19 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
Free light upgrade for 4-headlight cars: swap high and low beam connectors on the lights.
Edit: I have yet to try it myself, but in theory it should work great. :P
Torque is offline
post #11 of 13 (permalink) Old 05-26-2005, 01:43 PM Thread Starter
[snapback]348071[/snapback]
LMAO!! That would be the funniest shit in the world...could you imagine someone actually doing that...that would be a blonde moment for sure.... :P
post #12 of 13 (permalink) Old 05-26-2005, 09:28 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Originally posted by Scotty Dangles+May 26 2005, 02:43 PM--><div class='quotetop'>QUOTE(Scotty Dangles @ May 26 2005, 02:43 PM)</div><div class='quotemain'><!--QuoteBegin-Torque@May 26 2005, 01:19 PM
[snapback]348081[/snapback]
[/b][/quote]
Why do you say that ?
Torque is offline
post #13 of 13 (permalink) Old 05-26-2005, 09:39 PM
bavarianasian is an unknown quantity at this point
this is a response to the guy with the silverstars. any headlight EVER should not be going out after two months. oem or aftermarket. something is just wrong there.
bavarianasian is offline
Lighting Question -- Amber Vs. Silver Glass Bulbs WindowPro 5-Series (E12,E28, E34, E39, E60) 8 11-08-2004 12:38 PM
Just got my 320i: Small question harpax 3-Series (E46, E90) 18 06-17-2004 04:24 PM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
Ambiant Lighting focusedonsound 3-Series (E46, E90) 2 02-03-2004 08:18 PM
Question about Lighting jrhaile 3-Series (E36) 5 02-02-2004 10:23 PM
