lifting engine to replace steering rack - question - BMW Forum - BimmerWerkz.com
Old 03-23-2008, 09:45 AM   #1 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
OK -first off I did spend a good deal searching for this answer but couldn't find something specific to my questions.. if someone has a link to a thread that provides these answers please post it!
I am going to be replacing the steering rack on my 97 e39 528i and do not have the facility to lift the engine as the bentley manual states you must do to pull the rack. Is it possible to lift the engine from underneath, and if so, what is the specific jack point to raise the engine the required 1.6 inches?
Thanks for any help....
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 03-23-2008, 12:48 PM   #2 (permalink)
Car: E30 318i, E30 318is, E30 M3
dvmotorsports is on a distinguished road
you'll need to borrow a hoist. i don't know a way to jack and support the motor from the bottom.
BMW Technician
dvmotorsports is offline   Reply With Quote
Old 03-25-2008, 10:27 PM   #3 (permalink)
Car: 1997 BMW 528i
cool, thanks for the response. I talked to my next door neighbor, who is also a mechanic (who now owns a used car lot) and he just happens to have a portable engine hoist at his dealership that he is going to bring home this weekend to let me use...It's great to have good neighbors!!
Jason / 1997 528i
Old 03-26-2008, 12:34 AM   #4 (permalink)
hey what part of jax are you in? i lived there a few years ago in neptune beach. i left right before they built the pier.
BMW Technician
Old 03-26-2008, 01:11 AM   #5 (permalink)
Car: 1997 BMW 528i
I live down in Julington Creek, but work downtown. Been here in Jax a long time, since '74 when my parents moved here from Ohio.
Jason / 1997 528i
Old 03-30-2008, 01:23 PM   #6 (permalink)
Car: 1997 BMW 528i
Ok, well I am halfway into replacing my steering rack today. #4 step was to raise the engine. Getting to the rear engine hook is just too much of a pain without having to to remove a whole bunch of stuff, especially if you don't have the BMW engine lift tool (which I dont). So I decided to test and improvise..
I undid the right and left engine mount nuts, then took my floor jack and put a 4x4 block of wood on top of it. I then put it right up to the bottom of the engine block and started to lift, very gently. It seemed to move just fine without pulling any wires, hoses, or anything, and I was able to jack it up the required 40mm to allow the steering rack to be removed. The only thing that seems to be in the way of the engine moving much further is the fan shroud. I would think you could use this method to easily replace engine mounts as well, but you would have to remove the fan shroud, as it just needs about 1cm more clearance to get the mounts out easily.
I will take some pics of he location I put the jack and 4x4 and post it later tonight.
After I finish this yummy turkey sandwich I'll be heading back out to pop the tie rods off and get this sucker replaced.
Jason / 1997 528i
Old 03-31-2008, 08:06 PM   #7 (permalink)
Car: 1997 BMW 528i
Well got it all buttoned up yesterday evening, took me about 5 hrs total. Getting the rack out was like one of those crazy puzzles with the nails..after some twisting and turning it just popped out and I was able to slide it out from above the subframe. Turns out one of my tie rods was toast so I had to hit the stealership this morning for one ($90 later..) and was able to get it installed in about 15 minutes. Then ran it up to the local tire place for a quick alignment. rides straight and smooth now, and no more leakage! Quite the job, however, not one I would recommend for the beginner.
Jason / 1997 528i
Steering rack question lt1_man 3-Series (E21, E30) 1 09-22-2007 05:50 AM
Steering rack shopkeep 3-Series (E21, E30) 4 07-29-2007 11:42 PM
new steering rack WarNox 3-Series (E36) 15 08-15-2006 06:07 AM
Help??? Steering Rack Problems ArtCarr 3-Series (E36) 1 02-08-2005 10:16 PM
Steering Rack..... dubes1982bmw320i 3-Series (E21, E30) 3 10-29-2004 08:36 PM
