Lets Talk Climate Control - BMW Forum - BimmerWerkz.com
post #1 of 19 (permalink) Old 12-07-2004, 10:38 PM Thread Starter
RIPN RAY is an unknown quantity at this point
so i just bought a 93 525i trying to figure out the climate control but i think my problem is that it's not working correctly. one thing that tells me that is because only cold air will come out of the rear vents in the center console.
why does it do that?
someone want to explain the section on the fan dial that is not off or a numbered position?
in between the vents in the center of the dash board is a dial that can either point to a blue dot or a red dot. what does that do?
RIPN RAY is offline
post #2 of 19 (permalink) Old 12-07-2004, 11:07 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute Torque has a reputation beyond repute
Rear vents don't get hot air...only for fresh air from the outside. Check the attached diagram.
Torque is offline
post #3 of 19 (permalink) Old 12-07-2004, 11:09 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
one on the dashboard i never quite understood. i guess it selects where it takes the air in from ?!? engine compartment or the outside. i dont know that one. i have mine on cold when air con is on and on hot during cold months.
Torque is offline
post #4 of 19 (permalink) Old 12-08-2004, 02:57 PM
liquidtiger720 is an unknown quantity at this point
Send a message via AIM to liquidtiger720
the knob in the middle controls heat. specifically ventalation heat.
liquidtiger720 is offline
post #5 of 19 (permalink) Old 12-08-2004, 07:06 PM
billB's Avatar
billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute
[snapback]245907[/snapback]
I am not so sure because it does control the AC as well. Not the Compressor proper but how cold/how hot the air should get. Turn it to the 1st blue dot on 60 degrees, then turn it toward more blues on same degree; it gets colder; same holds true for heat when on 90 while turning red dots!
Who wants to solve the mystery of the middle knob?
I like to think of it as the main console climate control TRIMMER/FINE TUNER if you wish. I noticed more blue= colder AC (independent of main temp setting controls below it) when more red=hotter. While I sound so silly talking reds/blues here; I noticed when turned red while AC is on, cold air becomes less cold and thus a trimmer/mixer/tends to mix hot and cold!! Wow does this make any sense to you guys?
Note: Whether I engage it or not I have AC and/or heat (controlled by the dual main console) but when engaged it tends to fine tune the main climate settings (+ and -) ANYONE? Shed some lights please and correct? What is the internal working mechanism of the knob? Does it act on heater valves/sword and/or AC system? How?
regards
billb
billB is offline
post #6 of 19 (permalink) Old 12-09-2004, 01:03 AM
good point bill. never tried it with the AC on.
post #7 of 19 (permalink) Old 12-09-2004, 02:46 AM
CosmosBlack's Avatar
CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute
There is a name for that dial, I just can't remember what it's called.
Anyway, that dial controls the temp of the air that blows out of the vent.
The temp settings on the center console however controls the ambient temperature of the interior surrounding.
Which means you can adjust the air to blow out cold or hot from the blower, but whatever temp is set on the climate control, when it reaches that set temp, the AC cuts off or turns on automatically to maintain that set temp.
Makes sense?
2012 Porsche 911 GTS
2008 Ford F150 Foose Edition
2010 VW Touareg
Gone...2002 Porsche 911 C4S
Gone...2000 BMW 540i
Gone...1995 BMW 540i
CosmosBlack is offline
post #8 of 19 (permalink) Old 12-09-2004, 12:18 PM
billB's Avatar
Makes sense?
[snapback]246335[/snapback]
Cosmos..long time no see!
when you set the temp on the climate control, the vents keep on blowing air (hot or cold) until the TEMP SENSORS (located to the sides of the control and possible on the overhead) read that exact temp and sends a cut off signal.
So to summarize,Three things:
1. The main unit to set temp and get the system going hot or cold.
2. Then sensors (independent components) watching out fo the cabin temp. Think your heater thermostat at home set at 70 shuts down your boiler at 70 once room temp reaches 70. When room temp drops, it kicks in again and hence Auto on console. Example set temp at 70 but don't engage the auto switch, air will keep blowing forever; now kick in auto; at room 70 it will cut off= sensors
3. This is the middle guy puzzle! I say it is a trimmer/fine tuner see above.
But I still don't know the internal mechanism of this thing. Someone will have an answer, I am sure used
Regards
billb
billB is offline
post #9 of 19 (permalink) Old 12-10-2004, 12:58 PM
mrogers's Avatar
mrogers is an unknown quantity at this point
I read what it was in my manual. It's just a control to "temper" the air that typically blows onto your face. I use it a lot. For example, I want the cabin to be warm, so I set the climate control to 68 degrees, but I don't want air that warm blowing right on my face, so I flip the dial toward the blue. That way, I get some semblance of refreshing air on my face while the rest of my body is still nice and warm. I do the reverse in summer with the AC--while I want the cabin cool, if I have the cold air blowing right on my face for an extended period of time my nose starts to get too cold , but I don't want to turn the climate control temp up because then the whole cabin gets too hot. It's a nice feature.
Anyone who ever buys used cars online, anyone even THINKING of starting a &quot;Is this deal too good to be true?&quot; thread, anyone who wants to be more educated about protecting themselves must <a href='
target='_blank'>read this</a>.
<img src='
mrogers is offline
post #10 of 19 (permalink) Old 12-11-2004, 04:32 PM Thread Starter
ok, now does someone want to try to explain the fan control dial?
RIPN RAY is offline
post #11 of 19 (permalink) Old 12-11-2004, 06:09 PM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
[snapback]248104[/snapback]
eh ?
it controls the volume of hot/cold air (depending on what you pick) the fan blows in. it's self-explanatory.
Torque is offline
post #12 of 19 (permalink) Old 12-11-2004, 08:18 PM
billB's Avatar
Originally posted by Torque+Dec 12 2004, 12:09 AM--><div class='quotetop'>QUOTE(Torque @ Dec 12 2004, 12:09 AM)</div><div class='quotemain'><!--QuoteBegin-RIPN RAY@Dec 11 2004, 05:32 PM
eh ?
[snapback]248146[/snapback]
[/b][/quote]
Guys it all depends on year/model of the car! mine is 97/528i does not have a fan control dial. It has a horizontal switch with a (+,-) symbol plus the AUTO. Other cars have a round dial to control the fan.
I thought we were talking about the THING living between the two outlets high up on the dash. That THING has nothing to do with VOLUME, it is related to the how cold/how hot you want it (think degrees/intensity not volume) as I explained above.
Basic system:
A. fan speed=This is volume; my switch,or dial has min-max range, 3,4 speeds etc (see Torque explanation above)
b. temp. setting= blue-red, degrees from 60-90 single, dual zones
c recirculation button= outside air vs. reserc.
d. Auto: keeps temp constant, after it has been reached, also your AC comp. will kick in here. Just like pressing the blue button with the snow thing on it.
e. The defrost: winshield flow direction with AC comp. kicking in whether you like it or not!!
f. THE THING: I called it a trimmer what ever your temp is set at it will intensify it towards the + or it will make it milder towards the + or - depending on which temp you choose.
I know I made it worse....see my post above....
The million dollar question is : HOW does it work?its internal mechanism. We all have the car manual!!!
billB is offline
post #13 of 19 (permalink) Old 12-11-2004, 11:29 PM Thread Starter
ok so we got the dial in the middle of the vents figured out.
now i want to know about the fan dail. what is the section between the 0 and 1? is that the "auto" which will control the fan speed for you?
for example: what will the fan do in this position
RIPN RAY is offline
post #14 of 19 (permalink) Old 12-12-2004, 12:08 AM
Millions of them.
Torque's Avatar
Quoted: 1 Post(s)
it will blow very little.
Torque is offline
post #15 of 19 (permalink) Old 12-12-2004, 02:48 PM
billB's Avatar
Don't you have to move one of the 3 levers to the right to get the system going? The temp is 72 degrees!!!
billB is offline
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 12:47 PM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 10:59 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 10:09 AM
Climate Control Unit mmclaren 3-Series (E36) 2 06-20-2005 08:33 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 12:51 PM
