Knocking Noise - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 01-08-2004, 02:28 PM Thread Starter
CaptainEL is an unknown quantity at this point
This is for my brother he has a 1989 G 535i Sport Auto.
It started getting a knocking noise coming from the back passenger wheel only when he accelerated???
We jacked back up but couldn't hear or see any reason for the noise. All the wheel nuts where fine and drive shaft seems ok.
Then when we took the car back off the jack the noise has seem to gone.
Was just wondering if anyone has had this problem or if they new what it couls be.
CaptainEL is offline
post #2 of 6 (permalink) Old 01-08-2004, 04:52 PM
Maz
Maz is an unknown quantity at this point
Send a message via AIM to Maz
The U joints/bolts in the Drive shaft might be stripped or bad!! The same thing happened to mine but it was begind my seat and not hte passenger
Maz is offline
post #3 of 6 (permalink) Old 01-09-2004, 03:41 PM Thread Starter
Where are the U joint bolts???
post #4 of 6 (permalink) Old 01-09-2004, 05:55 PM
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
on the drive shaft infront of the rear diff
all you ever need for the toronto night life <a href='
target='_blank'>click here</a>
<img src='
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline
post #5 of 6 (permalink) Old 01-10-2004, 12:39 AM
E28boi's Avatar
E28boi is an unknown quantity at this point
could be the center bearing on the drivshaft also or the flex disc(guibo) behind the tranny and in front of the driveshaft (if the car is so equipped)
86 535i
99 Passat V6
E28boi is offline
post #6 of 6 (permalink) Old 01-26-2004, 10:22 AM
XoticSoundz is an unknown quantity at this point
i have a 1986 528e and i just had to replace the "Center Support" or "Driveshaft Support" it is located near the center of the car and there is rubber around the bearing that makes it work... that rubber goes bad and therefore the driveshaft can then move around causing what you are refering to(as long as it sounds like someone hitting the bottom of your car with a hammer) to replace you must unbolt the Transmission crossmember(dont forget to inspect the tranmission mounts) then you have to unbolt the driveshaft (8 total bolts) and then my friend you have to get the damn center support Pressed on(and all the meanwhile your U-Joints are probably bad.... mine were) this 25 dollar part put my car out of commission for a good 2 months.... ghead
XoticSoundz is offline
What the HELL is making this NOISE???? bimmer_boy 3-Series (E36) 28 01-18-2008 08:15 PM
Ticking Noise From Engine Clint_M 3-Series (E36) 9 11-07-2004 12:02 PM
e34 knocking noise from engine d3ity 5-Series (E12,E28, E34, E39, E60) 8 07-14-2004 01:45 AM
loud noise - including clicking tsinghbmw 3-Series (E36) 6 06-01-2004 03:25 PM
