just purchased a 97 540i 6speed - BMW Forum - BimmerWerkz.com
Old 03-08-2008, 07:47 PM   #1 (permalink)
Bimmer540i6's Avatar
Car: 1997 540i 6sp
Bimmer540i6 is on a distinguished road
Hello peoples just wana say im new to the forum and i recently got my hands on a nice 540I and im just wondering if anyone knows how to check the tranny fluid. I opened what looked like the fill hole at the tranny and i didnt really feel any fluid when reaching in.
p.s. no thats not my bimmer in the pic lol
Bimmer540i6 is offline   Reply With Quote
Old 03-08-2008, 08:49 PM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Welcome to bimmerwerkz!
As fas as I know, checking through the fill hole is the only way to check the fluid level, which would scare me a little if you weren't able to feel any fluid in there. That is the extent of my knowledge, however. Check back, as someone who'll be able to tell you more shall swing by sometime soon.
Good luck and welcome again
Turkey Fleet Bond Holder
Old 03-08-2008, 11:58 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Welcome and congrats on the purchase.
The way to check the fluid is: raise the car up so it's level (put it on 4 jackstands on a level surface), and open the fill hole bolt (the one from the side -- horizontally, not the one on the bottom). The fluid should be right to the bottom of the hole (meaning if you add any more in, it starts dripping out the hole).
The procedure for changing the fluid is simple too: open the drain plug on the bottom, let it all drip out, reinstall the bolt, remove the fill bolt on the side, and keep adding until no more can go in. Then put the plug back in.
edit: If you don't have 4 jackstands, it's probably cheaper to swing by any shop and have them change your fluid. Don't go to the dealer ... anyone can do it, but do get the proper spec fluid.
Old 03-09-2008, 06:16 PM   #4 (permalink)
Car: 1997 540i 6sp
thanks!
thanks torque and drz, thats what i thought i should be able to see the fluid right at the top, i think it is leaking, when i did the oil change i did see a little wetness around the tranny seal, looks like its time for a new seal, ah crap lol...and am i right it says ATF on the tranny and not gear oil?
Also, if someone could tell me how to reset the maint. light, i know you gota jump that big connector under the hood somehow.
thanks alot!
Old 03-09-2008, 08:46 PM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
If it has the ATF sticker on the side of the tranny, use that. My car also uses it.
As for the service light reset on the e39 ... I think you need a reset tool; not 100 percent on that though.
Old 03-13-2008, 10:28 AM   #6 (permalink)
solanog is an unknown quantity at this point
There is a procedure for resetting the light without the tool, you shortcut one of the pins but I don't remember which. You can search something like "resetting the SIL" or something similar.
solanog is offline   Reply With Quote
Old 03-13-2008, 11:10 AM   #7 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Welcome to the joys of the E39. I see you're in New York too. Whereabouts?
Lindsay fan club member.
Old 03-13-2008, 11:21 AM   #8 (permalink)
A NEW DAY RISES...
RoadsterMadness's Avatar
Car: 2008 M5, 2011 X5
RoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud ofRoadsterMadness has much to be proud of
Yes greetings and welcome to Teh WERKZ!
2008 ///M5 with Eisenmann race exhaust "Athena"
2011 X5 - Loaded - N55 twin scroll turbo 300hp
RIP 2005 Dinan ///M3 S3-R+ Vert w/hardtop- 6-speed, DINAN SC - race kit, race headers, etc.
RIP 2002 Z3 Roadster 2.5i - VF Supercharged, 5-speed, Brembos etc.
Turkey ///M Car Fleet Commander
TINA FAN CLUB PRESIDENT
RoadsterMadness is offline   Reply With Quote
Old 03-13-2008, 11:25 AM   #9 (permalink)
This should help
Reset The SIL
Old 03-13-2008, 11:33 AM   #10 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
welcome
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
fs: 99 e39 540i 6speed bimmerwhore Cars For Sale 4 08-16-2007 02:32 PM
1/4 track times for my 540i 6speed thejobman 5-Series (E12,E28, E34, E39, E60) 18 06-08-2006 09:34 PM
Just Purchased 87 528e figo 5-Series (E12,E28, E34, E39, E60) 5 03-25-2005 10:14 PM
Has Anyone Purchased An Ebay... dblmikeusa1 3-Series (E36) 21 03-06-2005 10:18 PM
