I need to check the belt but, I have asked one electrician about it & also showed the problem to him. Yesterday. He told that it is the steering pumb which requires replacement.
The belt sound more possible to me but need to check the condition. Will apprecite if you till me how to identify the belt & check its condition ….
I think/hope it's the belt slipping when the pump is under max load. If the belt looks at all worn get it changed. (Small fine cracks at 90 degrees to the grooves on the inner surface are ok)... but any damage to the outer, or running along the grooves means you need a new one. Of course you may just need the tensioner adjusting. Get the tensioner pulleys checked for wear if you are doing a belt change..... lost one of mine recently.... new rad!
The mechanic confirmed the noise is due to the belt tensioner that need to be changed & hence I replaced it, but the noise is still there!!! I am planning to take it to him again in the coming weekend. Any idea on what is the next possibility?
What you're describing rashid sounds like a steering pump on its way out, unfortunately. This would be particularly true if you can feel a jerk in the steering as well as hear it.
