Issues changing 525i transmission fluid - BMW Forum - BimmerWerkz.com
Old 03-25-2008, 05:28 AM   #1 (permalink)
kenseius is on a distinguished road
Question Issues changing 525i transmission fluid
Hey, I'm new to this forum / website.
I have a 1993 525i, which recently needed it's radiator replaced, which meant we drained some of the transmission fluid. So, to replace it, I found the valves--- the drain and the intake, but the intake valve is so rediculously hard to access, I rigged up some tubbing and tried to drain it in, with no luck... I need a pump of some kind, I guess, but do you have any suggestions?
Also, a bit of the tubing has fallen inside through the intake valve... any suggestions on a way to get it out?
Thanks!
kenseius is offline   Reply With Quote
Changing automatic transmission fluid fastshivy 5-Series (E12,E28, E34, E39, E60) 17 02-10-2007 06:58 AM
transmission issues ProjektMayhem 3-Series (E36) 7 04-02-2006 03:04 AM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Transmission Issues Exposay 3-Series (E21, E30) 1 08-28-2004 08:46 PM
Automatic Transmission Fluid / Steering Fluid akbarz 3-Series (E46, E90) 1 08-23-2004 02:04 AM
