Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 04-28-2008, 02:56 PM   #1 (permalink)
Photos: 0
bmwcincy is on a distinguished road
intermittent "ticking" noise e60 2004 530
i have a very annoying intermittent ticking noise that comes through the speakers for every audio source in the car (AM/FM/CD/even the tones for the seat belt reminder and when a door is ajar). The noise sounds kind of like a CD skipping and is completely sporadic, but it's consistent in the fact that it's always there.
I've search every forum I can find and haven't found this problem anywhere else. The dealer claims that I need the software re-loaded, but also warned that could cause me other issues. I think it's hardware, not software because it is worse (louder) in the summer. Also during the winter it takes about 10 minutes a driving before it starts ticking.
Any idea what this could be? I've already replaced the head unit with a radio from a 2005 530 and it made no difference. I've also disconnected what I assume is the bass amplifier in the trunk on the driver side, but the "ticking" sound is still there.
bmwcincy is offline   Reply With Quote
Old 04-29-2008, 09:51 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
perhaps let them update the software?
DT
VIEW MY GARAGE
My 540I6
My Site
Old 04-30-2008, 08:50 AM   #3 (permalink)
Photos: 0
DT - thanks. I've considered having them update the software, but the charge is $895. Also, I was warned by the BMW service department that updating the software could screw up something else. It feels like an expensive, slippery, slope.
Old 05-03-2008, 04:37 AM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
Thats pretty steep for a software upgrade only. Average should be around 3-400 tops.
If you swapped the M-ASK (radio) already then the next 2 most common culprits would be the amplifier or the TCU (telematics control unit.) If you just disconnected the AMP and left the fiber optic lines just hanging there then that could cause noises on its own due to the light attenuation. What you really need to do is jump the fiber optic leads at the module so that the light is fed to the next module and therefore you are essentially bypassing the module. This can be done using a "MOST BUS" optical jumper which you can buy from any BMW parts department. If you have been reading on all the forums as you mentioned then you should be familiar at least somewhat with MOST BUS by now. All of your entertainment modules are basically "looped" together in series in a fiber optic ring known as MOST BUS. Popping noises are usually due to light attentuation on the MOST BUS. This can be from lots of things but most of the time its due to a failing module which is pulling the light signal down. As I mentioned before if you have eliminated the M-ASK then the next most common 2 would be the AMP and the TCU then you could go from there depending on your equipment level. If the TCU is failing then your dealership can give you the option of coding it out of the system to save you the replacement cost. Irregardless of what it needs if you are out of Factory warranty then any coding or repairs can quickly get very pricey. If you do replace any modules yourself keep in mind that they MUST be coded to the vehicle by a dealer. Also keep in mind that most used modules can not be fitted to another car and coded because they are already married to the original vehicle that they were installed in. Hopefully some of this info helps.
DT
VIEW MY GARAGE
My 540I6
My Site
Old 05-12-2008, 08:03 AM   #5 (permalink)
Photos: 0
Thanks for taking the time on this. It's appreciated.
vB code is On
E60 (550) but Front "M5" Wheels Rub ramseti 5-Series (E12,E28, E34, E39, E60) 7 02-10-2008 01:53 AM
Where Do I Connect The "tuning-box"? (e60) Martins 5-Series (E12,E28, E34, E39, E60) 0 01-04-2005 05:33 AM
E60 - 17" or 18" wheels wanted skainth Classifieds Sell & Buy 5 08-23-2004 04:19 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
