interior lights - BMW Forum - BimmerWerkz.com
Old 01-29-2009, 11:52 PM   #1 (permalink)
wayne33 is on a distinguished road
interior lights
hello everyone I have a 2002 e39 530i/6. Heres the deal when i turn car off close the door and lock the doors the interior lights turn off shortly after. now the light on the shifter stays lite. Has any one had this kind of problem? I had battery AND ALT. CHECKED. what had me check these is something was killing my battery. then I Noticed the light.
THANKS AHEAD OF TIME
WAYNE
wayne33 is offline   Reply With Quote
Old 01-30-2009, 12:06 AM   #2 (permalink)
You're looking for a faulty relay issue.
Old 01-30-2009, 12:24 AM   #3 (permalink)
Any idea which one
Old 01-30-2009, 08:47 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Wayne, Obviously something is staying on and draining your battery.
1. You can check the cigarette lighter (remove it and don't put it back on to verify).
2. Check your glove box interior light. The light was staying on with the glove box compartment closed in my case.
3. Check the trunk lock and make sure the light is not staying on when closed.
The light on the shifter should stay on for a bout 10-15 minutes and then it turns itself off.
LOS
Old 01-30-2009, 09:31 AM   #5 (permalink)
BMWides110377's Avatar
Car: 2002 325i
BMWides110377 is on a distinguished road
Send a message via AIM to BMWides110377 Send a message via MSN to BMWides110377 Send a message via Yahoo to BMWides110377
My 02 E46 shifter light stays on for about 15 minutes as well so I doubt that is what is draining your battery....also, it is an LED so there is minimal amps needed to keep it lit....
BMWides110377 is offline   Reply With Quote
Old 01-30-2009, 01:37 PM   #6 (permalink)
hers the problem: so did research for hour last night. came accross some info. so i thought i will check final stage unit. now its 30-40 degress in my garage. so i got down to part, touched it and it was burning hot. after being parked for 10 plus hours. seems to be a coomon problem. now is there a better place to get it less the dealer?
final stage unit
Interior lights go out? Handsome Rob 3-Series (E36) 4 03-02-2006 08:42 AM
Interior Lights Not Going Out!! komodo 3-Series (E36) 2 12-12-2004 12:34 AM
Lights In The Interior flamba 3-Series (E46, E90) 1 12-02-2004 09:38 PM
No Interior Lights Pokeeys_318 3-Series (E36) 1 10-20-2004 04:38 PM
Interior Lights CiscoKid 3-Series (E36) 16 06-21-2004 08:18 PM
