Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» Tire Upgrade Garage
Sponsors
Sponsors
Old 03-13-2008, 10:37 AM   #1 (permalink)
Photos: 0
solanog is an unknown quantity at this point
Instrument cluster for e39
My brother's car (1999 523i) has the instrument cluster damaged. Tach, speed, temp and fuel gauges are working fine but the odometer, trip odometer and indications from the trip computer don't show well. Seems like the LEDs conforming the kilometers and mesages from the computer don't work correctly, at some moments they are O.K but most of the time they don't light completely.
Seems like this is a common problem among this cars, can this be repaired or should the part be replaced?
Where can this part be found?
Thanks
solanog is offline   Reply With Quote
Old 03-14-2008, 09:27 AM   #2 (permalink)
Twin Que's Avatar
Photos: 0
Twin Que is an unknown quantity at this point
Very common problem
Hey guy,
This is a reoccuring problem with this model (E39). BMW recognizes the problem and have offered many a repair solution. It is a design flaw. There are several ways to fix. Try BMW first to see if they will repair. If not, you can google search the internet for a VDO display repair shop. There is also a self fix (DIY) which requires partial disassembly. I tried the later and screwed up. Fortunatley, I was able to find a used instrument cluster. All the pixels worked on the replacement.
Good luck
Friendship is Essential to the Soul
Twin Que is offline   Reply With Quote
Old 03-28-2008, 01:06 PM   #3 (permalink)
Photos: 0
drakulita is on a distinguished road
Twin Que, I have a brand new replacement cluster I got a while back on ebay for cheap but I'm worried about putting it in if that would screw up the odometer, was there an issue for you about that? Also, what model do you have, because at least here in the states the 540 is a different cluster from the 528 - the 540 has the same one as the 7er.
drakulita is offline   Reply With Quote
Old 03-30-2008, 04:01 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
If the cluster truely is a new part then the mileage should be blank. Regardless of what you do the only proper way to replace the cluster is to have it coded by the dealership or someplace with dealer quality software. this way the mileage can be transferred fromt he LCM which stores the mileage redundantly with the Cluster. What is also very important is that the ZCS (central coding key) which houses the list of all options installed on your vehicle is also transferred to the new cluster which can only be done during coding. if the cluster truely is new then this shouldnt be a problem.
Also there are 2 different clusters available for the e39 regardless of the model (528 540 whatever) there is a high version and a low version. High version will have a matrix display and will give you check control messages in text format. The low cluster has a pictogram of a car on the left side and gives you check control warnings by displaying a symbol on the pictogram of the car.
DT
VIEW MY GARAGE
my 97' 540I6
My Site
Old 03-31-2008, 11:57 AM   #5 (permalink)
Photos: 0
Yes, I need the "high Version" one.
Old 05-08-2008, 08:18 PM   #6 (permalink)
Photos: 0
Spinn is on a distinguished road
I have the same problem on the 540 I just bought and it will not get through Maryland Inspection.
Where can I find this on the net. I am having a tough time finding one.
Spinn is offline   Reply With Quote
Old 05-09-2008, 09:17 AM   #7 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
You are replacing the cluster unit???
Try BMW Parts used and rebuilt bmw auto parts or dealer...
Good luck
LOS
Old 05-09-2008, 03:46 PM   #8 (permalink)
Twin Que's Avatar
Photos: 0
I have an extra for sale. The cluster shows 140K miles but all the pixels work. As long as the replacement has more miles than the original one, it will work no problem. Less miles will show the cluster tamper light, not cureable.... If you want, email me and let's make a deal....
Old 05-09-2008, 04:01 PM   #9 (permalink)
Photos: 0
The car I'm talking about is in Km, are they switchable between km and miles?
Old 05-09-2008, 10:23 PM   #10 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
the vehicle's VIN # is stored in the cluster and if you put a used cluster in your car the vin # will not match yours and you will absolutely get a manipulation dot regardless of whether the miles are less or more.
DT
VIEW MY GARAGE
my 97' 540I6
My Site
Old 05-09-2008, 10:23 PM   #11 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
this can be changed via coding.
DT
VIEW MY GARAGE
my 97' 540I6
My Site
Old 05-09-2008, 11:44 PM   #12 (permalink)
Photos: 0
Lisa-Adam is on a distinguished road
The instrument cluster can fail on certain gauges- loss of rev counter, speedo, fuel gauge, 3 (E36) and 5 (E39) series BMW instrument cluster.
Gary Winnick providing worldwide computer networking services.
Lisa-Adam is offline   Reply With Quote
vB code is On
E39 Instrument Cluster replacement mileage questions BaksTab 5-Series (E12,E28, E34, E39, E60) 9 10-20-2007 04:06 AM
E39 Instrument Cluster Help emzet 5-Series (E12,E28, E34, E39, E60) 6 08-21-2007 09:23 PM
M3 instrument cluster nobrakese36 3-Series (E36) 6 01-05-2006 02:32 AM
E39 540i 1996 Instrument Cluster Change meditek 5-Series (E12,E28, E34, E39, E60) 5 04-18-2005 04:25 PM
FS: E39,E38,X5 Instrument Cluster Speedometer nit78 Classifieds Sell & Buy 0 12-31-2003 04:24 PM
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
SEO by vBSEO 3.1.0
