OK, i have a burnt out light on my temp gauge and a little squeak INSIDE the instrument cluster, and i want to fix the bulb and the squeak, however.... my steering wheel is a non-tilt wheel and i do not feel comfortable with removing the steering wheel / airbag, but i cant really afford to have this fixed at BMW.
Does anybody know an alternate way to lower the steering wheel or to remove the top part of the dash on a 1990 525?
If there isn't enough room to slide the cluster behind the wheel, then remove the steering wheel.
Diconnect the battery, and you'll avoid setting off the srs light.
I don't ever disconnect the battery, like you're supposed to do, I just keep the key off.
But I'd disconnect the battery, remove the airbag-there are two torx bolts behind the steering wheel, probably 25 or 27, maybe 30 in size.
One bolt holds the steering wheel on.
Be careful of the slip ring connector, you should disconnect it before yanking on the wheel.
Be sure to mark the wheel so it goes back on straight.
I had a similar problem. My check engine light would nto turn on!! now stupid california state laws say that light must turn on as soon as u turn on ur car for emission standards, wat bullshit. I passed emissions easy but they failed me cuz that little bulb....anywho wut u do is u start pulling out the cluster and turn the wheel so that teh cluster partially stick out of the wheel. this way u can slide ur hands, ur little cuzins hands, or ur kids hands in their to reach the back and therebyhave access to the back of the cluster.
the instrument cluster should slide out without having to remove the steering wheel , if i can recall when i helped with one, once we got it looose from connections and pulled forward, we tilted the steering wheel all the way down and out, then put a rag on the wheel to avoid scuffing the cluster.
however i maybe mistaken now that i think of it. it might have been a different car but ill post this anyways just in case there is some validity to what ive wrote.
Nope i never got mine out, what i ended up doing was tilting it and sticking my hand through the wheel, putting my head in an awkward position and hoping i pulled out the right bulb! darn, i want tilt wheel! Good luck, i still have more bulbs to replace, liek my fog light bulbs.
I also have anothe rproblem with my cluster, it soemtimes goes haywaire. Gas gauge upside down, the lights behind my gas and temp gauges r always off, the lower part of the unit where the led displays information wont light up. i really wish to see this convenient innovation by BMW, will i have to dish out the dinero for a new unit? or is anyoen else havign this problem and able to fix it?
Thank you for the instructions TECH, but for peace of mind, i prefer to use that as my last resort - i just dont want to mess with any safety equipment in fear that it wont work (even if the airbag light didnt come on) - im just wierd.
Anyway, on bmwe34.net i read something about lowering the steering columnso the wheel drops down, but then it says that this can set off the airbag. Does anybody know how i could do it safely? do they mean it can set off the airbag if i let it drop hard?
