Inner Door Handle Replacement . . . - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 12-18-2004, 11:01 AM Thread Starter
devo528iA is an unknown quantity at this point
so how tough is it really to replace the driverside door handle on a 528i ?
how involved is it ?
thanks .
devo528iA
devo528iA is offline
post #2 of 3 (permalink) Old 12-18-2004, 01:18 PM
mrogers's Avatar
mrogers is an unknown quantity at this point
Did just the silver part snap? The cable didn't break, did it?
It's farily easy to remove the handle itself; you should be able to see a circular plastic covering in the black part behind the chrome handle, carefully pry it off with a flathead screwdriver and you will see the single screw that holds the handle in place. You will then need to detach the cable from the old handle and attach it to the new one; I don't have any details on that because I've never done it, but it shouldn't be too difficult. Then put the handle back in, screw it in, pop on the cover and you're all set.
Anyone who ever buys used cars online, anyone even THINKING of starting a &quot;Is this deal too good to be true?&quot; thread, anyone who wants to be more educated about protecting themselves must <a href='
target='_blank'>read this</a>.
<img src='
mrogers is offline
post #3 of 3 (permalink) Old 12-18-2004, 07:17 PM
BeelZibub is an unknown quantity at this point
This is amazing I performed this operation yesterday afternoon - Last week my drivers door handle suddenly came off in my hand, the back of it had broken. I took the one from the back (until I can get hold of another one) and fitted it to the front.
Now I performed this operation at 1.5C and my fingers were bloody freezing so if you're in a warm environment it should be a little easier.
Remove the screw cap from behind the handle and then remove the screw. The whole mount should now come out slightly - don't pull too hard on the plastic trim like I did, this then involves getting the back end of the trim top reattatch to the cable. You will see a metal cylinder with 4 lugs on it which you need to [push up and remove from the plastic trim. Now all you do is place your new handle in position and wiggle the metal cylinder back into place - you will need to [push down on this peice (located on teh end of the cable) with a little force to make sure that the little metel spur is locked into the plastic piece (you will know what I mean when you see it). Then just reassemble.
Sorry if this sounds like a load of random crap, if you have any probs I will take mine to bits and take pics for you to follow.
Good luck
BLZ
PS apparently this is a common problem - looking through the service record for my car it has already had 3 new door handles!!!!!
BeelZibub is offline
Synthetic Oil and filter CiscoKid 3-Series (E36) 47 04-14-2014 07:00 PM
Replacement Exhaust System Leo J. DeLeon 1,6,7,8 - Series and Mini Cooper 1 07-08-2005 03:45 AM
Replacement Hood Cost For 2000 323?? nmcruser 3-Series (E46, E90) 1 03-21-2005 03:07 PM
'88 528e Engine Replacement JPau 5-Series (E12,E28, E34, E39, E60) 3 03-15-2005 01:34 PM
`87 325ic clutch replacement - fair price? vidsal 3-Series (E21, E30) 1 11-22-2003 02:40 AM
