Indicator Lights - Brake/ABS/ASC-T - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 07-30-2008, 06:23 PM Thread Starter
kealamai is on a distinguished road
Aloooha! I'm new to this BMW site and couldn't find any postings of anyone else having these indicator light problems.
I have a 2000 BMW 528i, and the yellow indicators lights (Brake, ABS, ASC-T)
have all come on. Another weird thing is the same time these lights came on the speedometer and the odometer are not working either. I just recently did an oil change and I reset the oil change lights, could I have done something wrong to trigger this?
I unhooked the battery for a couple minutes and then the indicator lights went away and the speedometer and odometer where working again. What is the issue? Help!!! Is it something I can fix myself?
Kealamai
kealamai is offline
post #2 of 8 (permalink) Old 07-31-2008, 02:23 AM
darkhorse737's Avatar
Quoted: 2 Post(s)
Cool
if you don't have anymore problems... then it was just a "glitch".
all computer systems get "glitches" sometimes. sometimes from a static charge, sometimes from a current spike, sometimes fom radio frequency even.
Aloha
darkhorse737 is offline
post #3 of 8 (permalink) Old 08-01-2008, 12:58 AM Thread Starter
Hey Darkhorse737:
When I started the car this morning everything was back to normal with no indicator lights on. But when I drove home from work, the same problem happen. Do you think I need to replace the ABS computer module? I read that it's typical for those to go out in the 2000 5 series. What do you think?
kealamai is offline
post #4 of 8 (permalink) Old 08-01-2008, 10:43 AM
Quoted: 2 Post(s)
nope... i suggest you lessen the guesswork before you start replacing parts. (i.e. no point in replacing a module when all that might be necessary is to clean a dirty ABS sensor)
It's cheaper for you to have the car scanned for faults. With or without the lights on, the car computers would have stored the faults in its memory and can be retrieved by a code reader.
Good Luck.
post #5 of 8 (permalink) Old 08-01-2008, 12:20 PM Thread Starter
Thanks Darkhorse737.
kealamai is offline
post #6 of 8 (permalink) Old 09-30-2009, 06:13 AM
pablocruz is on a distinguished road
Aloha to all!!!
I realize I'm picking up this tread over a year later, but I'm having the same problem with the same car ABS and ASC Indicator lights go on etc... what resolved the problem? what was the problem? if you remember, please tell me. Thanks
pablocruz is offline
post #7 of 8 (permalink) Old 10-26-2009, 08:38 PM
BMWBumper is on a distinguished road
Hi All,
HELP!!! I have a 2000 323i with ~142,000 miles. About three weeks ago, my transmission won't go in reverse. I took my car to a family shop, they said my reverse gear is wore out. So it cost me $2,300 to rebuild it.
I picked up the car and drove it the next morning. As I was waiting at traffic light, I felt like someone push me from the back, this would happened intermittently. Also, when I was cruising at approximately 30mph to 40mph, I felt the gear slipped off intermittently. So I took it back to the shop and they recommended to replace wiring system. But then I have another problem, gear 1, 2 and reverse won't work. The shop ran the diagnostic and they said it is my ABS system. I do see the ABS warning goes on and off sometimes. So they claim that when ABS warning is on, gear 1, 2 and reverse won't work.
Please HELP if you do have advice on how I can get this repair correctly. All reply are much appreciated!!
BMWBumper is offline
post #8 of 8 (permalink) Old 10-26-2009, 09:34 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
The OP's issues I believe is the DSC module needs to be rebuilt(Which is a VERY COMMON e38 and e39 issue!)
To BMWBumper: this is a 5 series section you will have better luck in the 3 series section(your's is an e46 chassis)
your car might be going into "limp home mode" where it locks in 3rd gear....when was that last time your batery was changed(Please start a new thead if you havent alredy in the proper section and awnser there)
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
ABS, brake, and ASC warning lights on!? mantoboy 3-Series (E46, E90) 9 02-09-2009 07:54 PM
E39 brake abs and asc light came on ali054 5-Series (E12,E28, E34, E39, E60) 1 04-25-2008 12:02 AM
Abs,asc Lights On + Speedo Not Working ghazanfer 5-Series (E12,E28, E34, E39, E60) 2 06-06-2005 12:55 PM
ABS and ASC lights Henri 3-Series (E36) 10 09-01-2004 02:04 AM
My ABS and ASC lights just turned on... KingScare M-Series (M1, M3, M5, M6) 6 07-06-2004 10:37 AM
