For the last couple of weeks my 98 523 (2.5 ltr m52) has been running crappy at idle. I sprayed a bit of carb cleaner around the inlet manifold and the revs increased slightly - obviously needed a new manifold gasket then!! I've had this replaced today and tried the old carb cleaner test again - no leak, then why the bloody hell does she still idle like a bag of crap???? Idle control valve is likely a culprit but the thing is sometimes she will settle at idle perfeclty and I have to keep revving her to get the bad idle again, other times she will just consistently idle badly - does this sound like an idle control valve issue??? I thought they just died or can they just get a bit sticky? I disconnected the MAF and the idle problem went away, however after driving home with the MAF disconnected the idle problem returned. This might sound stupid but the problem always seems worse when I put her on my steep drive nose facing down <wtf??
Also there is an incessent rattle from the exhaust somewhere which started about 7-8 weeks ago as a little tinkling but now is a major rattle when the engine is started/revved. Last week I had a new hi flow Stainless cat, center box and rear box fitted not just because I thought it would aliviate this problem but because I had promised myself a stainless system for a while. The exhaust was a custom job and uses the down pipes from the original cat, is there anything in these down pipes that could cause a rattle - ie are they double skinned or something or can anyone think of a possible problem with the manifolds??? She had new manifold gaskets about 3 months ago. Just to let you know what the rattle sounds like, it really sounds as if a heat sheild is loose, but this isn't the case, all are in place firmly.
I dont have much time so I'll be quick. I also didnt get to read the exhaust part of your post entirely, so I'll read that and reply (if I can) later.
ICV CAN cause that problem that you are talking about. It's rare for it to be sticky, but it can be .. especially if it's just going on it's way out. Have you checked other vacuum areas? The MAF can definately cause the issue too. But that would cure the idle problems WHILE the engine is cold (each time it was cold) and would go back to crappy when it was warm. Even that, that doesn't garauntee the MAF, because the whole DME reverts back to many default settings.
Another rare issue is the ICM. (Idle control module - controls ICV)
I know the ICV isn't the EASIEST of jobs (not entirely difficult either) but you should try swapping it with a known working unit.
Exhaust - does it happen while driving? Can you locate the sound?
Often times a defective (or broken) catalytic converter can make the heatshield - type thin rattle.
If not, I would just suspect loose or non-existant rubber pieces in the exhaust hangers.
As far as the idle problem is concerned I don't know which way to go yet - Is it strange that she is not storing any fault codes though. Also when I disconnect the MAF the check engine warning light doesn't come on is this normal, I thought the MAF was quite an important part of the system. Also last week I pulled off each pluglead individually and started her up each time - no fault codes stored!!! Surely running on 5 cyls should create an error???
The exhaust still points to something in the downpipe/manifold. I am getting new stainless downpipes fitted next week to see if this cures the problem - if not it will be new manifolds - then if it should still rattle I will be hanging from a tree by the neck.
ICV will often not throw a code, but it's hard to garauntee.
The MAF doesn't always throw a check engine light, either. Usually only if it's been disconnected for a long time or if it has broken.
As for disconnecting plug leads - as long as they are firing properly - the ECU wont store a misfire code. Disconnect the coil pack completely and thats a different story
DEAR Beelz
1st Welcome back to our forum......long time no see.
You remember way back when my engine got flooded and I had to replace it.....the good news I do have an extra ICV sitting somewhere in my garage; the bad news is to find it.....how about this: I will look for it; once found will take a pic or two for you, also I will send you the part number ( I am not so sure if it fits your 523!!!!!...so check it out...it came out of 97 528i......Let me know f it fits please...and it is yours.....
DEAR Beelz
You remember way back when my engine got flooded and I had to replace it.....the good news I do have an extra ICV sitting somewhere in my garage; the bad news is to find it.....how about this: I will look for it; once found will take a pic or two for you, also I will send you the part number ( I am not so sure if it fits your 523!!!!!...so check it out...it came out of 97 528i......Let me know if it fits please...and it is yours.....
Thanks Sporky for the good input..I have found it in my garage...reading the black sticker on the ICV:
Bosch
0 280 140 545
1 744 713
Beelz if you are interested in the ICV just PM me with a mailing address (physical or P.O.BOX) and it is my pleasure to give it to you as a gift for a member and a friend who contributed alot of good info. to this forum.......
What about O2 sensors? They cause bad idling when they are turning bad.
And I'm surprised you could still drive the car with the MAF sensor disconnected!? When mine was faulty, the engine kept stalling!
Originally posted by CosmosBlack@Jul 9 2005, 06:59 AM What about O2 sensors? They cause bad idling when they are turning bad.
[snapback]360927[/snapback]
Lol, when the MAF was playing up a bit back I just disconnected it for a couple of days til I could be bothered to sort out the problem - as Sporky said they realise the MAF isn't operating and revert to a set of default parameters which is a "best guess" by BMW when the cars were manufactured. She ran much smoother with it disconnected than with a faulty MAF.
Thanks for all the input, here's an update.
After a week of having mechanics poking bloody great screw drivers around my heat shields, others telling me "it's definetly the down pipes want replacing", others "the manifolds must be rattling somehow", I decided to take off my collar and tie and revert to getting my hands dirty again (It's been a while). Within 60 seconds I had found the source of the rattle - the o2 sensor had somehow come loose and was sitting there rattling and vibrating like a bitch - HOW DID THEY ALL MISS THIS???? Anyhow, I now have a bloody great blister on my thumb from grabbing a hot o2 sensor but after a turn of the spanner I now have no rattle.
The idle problem is definetly on the inlet manifold somewhere. I had the gaskets changed but the problem is still there - A new can of carb cleaner and a couple of squirts around the inlet manifold brings the revs up just a little - it seems to be around cyl 5. I guess this means there is a crack in the manifold :-( I'm not quite sure what to do yet as I haven't got the premises for doing things like removing inlet manifolds and inspecting them - probably wouldn't be able to see a crack anyway.
