How To Remove The Rear Side Backrest. - BMW Forum - BimmerWerkz.com
Old 11-20-2004, 11:20 AM   #1 (permalink)
BMWhatever is an unknown quantity at this point
I'm trying to replace the rear suspension. The problem is that the upper strut mountings must be accessed inside the car. For doing that I have remove the side backrest (the cushion nearest to the door. I've removed the seat cushion but I cannot find any bolts for the side cushion. I see the bolt for the main backrest but not for the side one. The only thing I can see is that it is a bent metal bar that is stuck in the chassis. So you have to move the cushion up in order to get it out. The cushion is fastened somehere I don' know.
BMW 518g touring (e34) -96.
BMWhatever is offline   Reply With Quote
Old 11-20-2004, 05:20 PM   #2 (permalink)
billB's Avatar
BMWhatever
I am not sure if I read you correct: there are 2 parts to the seat: the cushion plus the back part? I am assuming you have a problem with the back support part; one piece that is. yes? let me know what you mean by the "side backrest" , the whole thing is one piece so try to lift upward (sometimes hard to lift) to release it from the 2 clips/hooks holding it in place. Good luck
biilb
Mammoth e36 DIY El Presidente Audio and Electronics 0 06-24-2004 01:02 AM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 08:08 PM
