How to remove the Fuel pressure regulator e39? - BMW Forum - BimmerWerkz.com
Old 10-01-2008, 12:39 AM   #1 (permalink)
Blackcatecho is on a distinguished road
Hey guys,
Just wanted to see if anyone can tell me how to remove the FPR before I try it myself without any advice. I'm having a low pressure reading at initial pressurization after it sits a while (.96 bar). I found the FPR and I just want to know how to disconnect it from the rail on my 97 528i. Thanks for any help.
Blackcatecho is offline   Reply With Quote
Old 10-01-2008, 05:44 PM   #2 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
You probably have to unmount the fuel rail to get to it. Pull the small vacuum hose off the FPR. If it's anything like the e36 6cyl engines, there's a circular clamp around its perimeter that has to be removed. This clamp houses a thrust washer that compresses the FPR against the opening on the fuel rail when the clamp is tightened. Just loosen the clamp and you'll see what I mean. Get a rag to cover & catch any fuel spill, and pull the FPR straight out. It might be a little hard to pull, since the o-ring inside maintains a tight seal.
If yours looks nothing like what I just described, then ignore this post
Dudesky_E36 is offline   Reply With Quote
Old 10-02-2008, 12:45 AM   #3 (permalink)
That sounds pretty accurate. Thanks for the post. That's how I thought to do it, but I just wanted to make sure that there wasn't any suprising step that I needed to know about. Thank again.
Bmp Afpr (adjustable Fuel Pressure Regulator) h4rdwire Aftermarket Parts 4 05-19-2005 04:11 PM
Need Fuel Pressure Regulator - What's Best On-line pcy 3-Series (E36) 0 04-20-2005 10:34 AM
Replacing Fuel Pressure Regulator shield 3-Series (E21, E30) 3 03-07-2005 11:55 PM
Fuel Pressure Regulator bluee36e36 3-Series (E36) 5 12-16-2004 09:41 PM
Replacing Fuel Pressure Regulator adavis 3-Series (E21, E30) 0 12-14-2004 02:25 PM
