how to put a door handle on e39 540i - BMW Forum - BimmerWerkz.com
Old 04-18-2007, 09:42 PM   #1 (permalink)
heartbreaker's Avatar
Car: 1993 BMW 325IS
heartbreaker is on a distinguished road
my dad asked me to put a door handle on his e39 540i (i guess this is common because he had one break off his 740il as well). anyway, does anyone know how to do this? does it require taking if the door panel? thanks for your help.
sam
93' 325IS show car
http://www.cardomain.com/ride/2368538
heartbreaker is offline   Reply With Quote
Old 04-26-2007, 06:06 PM   #2 (permalink)
Lone Star 528 is on a distinguished road
Are you talking about the inside door handle or the outside? If it's the inside, there is a screw you need to remove in the "cup" of the door handle. The plastic handle is attached to a rod with a hook on the end of it. It's easier if you use a pair of needle nose pliers to hold the rod while you remove the broken piece. Use the pliers to pull the rod toward the front of the door. The new handle goes on the same way. Takes maybe 10 minutes.
If you're asking about the outside door handle, no idea. Good luck.
Lone Star 528 is offline   Reply With Quote
Old 05-02-2007, 01:19 AM   #3 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
Yea, basically what lonestar said in regard to the inside handle. There is a guide you have to route the cable through in order for it to work properly on the new handle. You will see the guide when you get to work on it.
As for taking the panel off I did remove the part covering the side air bag to get a better idea of how the thing works. I broke off the foam like breakaway tabs along the top of the inside panel doing that. It wasn't that big a deal. I simply used some epoxy to keep it in place. It hasn't come lose in 2 years and you can't tell.
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline   Reply With Quote
Old 05-02-2007, 11:34 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
here is a link to replace the inside handle
Welcome to BMW Tips www.BMWTips.com
Just click on "tips & tricks", in the general section click, item 8
LOS
Old 05-02-2007, 11:52 AM   #5 (permalink)
teh Canuck....eh
PhatCat's Avatar
Car: '86 E30, baby! '05 Legacy 2.5GT Ltd
PhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond repute
Send a message via MSN to PhatCat
Duct tape works wonders
All great things are simple, and many can be expressed in single words: freedom, justice, honor, duty, mercy, hope.
Sir Winston Churchill
PhatCat is offline   Reply With Quote
1997 BMW 540i E39 Part Out! Ruskiepatzan 5-Series (E12,E28, E34, E39, E60) 2 12-29-2007 09:45 PM
Strange Event E39 540i meditek2 5-Series (E12,E28, E34, E39, E60) 0 12-30-2006 08:46 AM
Might pick up a Silver e39 540i tonight :) thejobman 5-Series (E12,E28, E34, E39, E60) 26 05-02-2006 10:40 PM
E39 540i Manaul Tranny pamato Looking For 0 10-21-2005 09:30 AM
e39 540i alternator and battery question HardStep 5-Series (E12,E28, E34, E39, E60) 5 10-11-2005 12:18 PM
