How to initiate my 525i after the battery is disconnected? - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 06-01-2013, 11:54 AM Thread Starter
lovecd is on a distinguished road
The battery on my 2005 525i needs to be replaced. However, I saw some words printed on the panel next to the battery apartment "initiate the car after the battery is disconnected...". What does this mean? I thought changing battery is just simple as removing the old one and put the new one. Why should I initiate the car in between? Can any one advice me how to do this step?
Thanks!
lovecd is offline
post #2 of 9 (permalink) Old 06-01-2013, 04:33 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
With the E60, theirs a computer module that adjusts the alternator current to the battery type. Give this a read as this will help you:
Battery Replacement in BMW E60 5 series – DIY - Bimmerfest - BMW Forums
And Follow Me on Instagram @E36M52
Founding Member of the Canyonrot Club! Paint Code #343
| OE M3 Bumper | M3 Mirrors | Max Velocity GTR Lip | Euro ZKW Projector Headlights | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks |
Lord Vader is offline
post #3 of 9 (permalink) Old 06-02-2013, 01:40 AM Thread Starter
Battery change
Thanks for that link, which is very helpful. By the way, the writer mentioned he used "jumping" method to keep those current settings during the replacement process, does it mean you need to use a jump cable, connect it with your BMW from another car's battery terminals and keep the engine of another car running? Or just connect the terminal without starting the other car? Any ideas?
lovecd is offline
post #4 of 9 (permalink) Old 06-02-2013, 04:41 AM
42, The meaning of life
brettski's Avatar
brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice
My understanding of the "jumping" process is to keep 12 volts on the cars system whilst you remove the battery. This can usually be done with another battery and a set of jumper leads. It doesn't even need to be a car battery because you aren't trying to run the car from it, its purely to keep the electrical system alive during the change over process.
Riding in style
brettski is offline
post #5 of 9 (permalink) Old 06-02-2013, 04:48 PM Thread Starter
I think I got that idea, so, if I use a jumper and connect the leads on my BMW, I need to power on the jumper, right?
Also, any ideas how to identify the type of the battery, AGM or FLA? I can only see the followings on my exisiting one:
850CCA, 205RC, 850A, 110AH, 12V, etc.
The Autozone store closed to my area has H8-AGM and H8-DLG ($25 cheaper), which one I should go with in order to avoid reprogramming the new battery after the change?
Any ideas?
Many thanks!
lovecd is offline
post #6 of 9 (permalink) Old 06-02-2013, 05:19 PM
4DoorWhore
Lord Vader's Avatar
Quoted: 2 Post(s)
Any ideas?
Many thanks!
Its not about programming the battery. Its about resetting the computer module for the voltage of the new battery. I would stick with the AGM battery.
post #7 of 9 (permalink) Old 06-02-2013, 08:07 PM Thread Starter
Thanks!
lovecd is offline
post #8 of 9 (permalink) Old 06-03-2013, 12:57 AM Thread Starter
After doing further research on this, I noticed that most AGM batteries are in black color and FLA is in white. My exisiting one is in white color, so, should I choose the H8-DLG this time?
lovecd is offline
post #9 of 9 (permalink) Old 06-06-2013, 01:19 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
the white 110AH battery is a lead acid battery. The AGM battery is a better battery however it requires "retrofit programming" in order to adapt the vehicles electronics to the AGM style battery. If you were to stick with a 110AH battery then the battery just needs to be "registered" to the vehicle using a diagnostic tool vs being "retrofit programmed" to the vehicle using a programming tool. The programming takes longer, is more expensive and is more invasive. For a professional coder/programmer it is no big deal but if you are taking the car to dealership or independent shop the programming will cost more than just the registration.
DT
Dirty_Tool is offline
How to do a Battery change in 2005 525i cindysuecj New Members Check In 3 08-07-2009 06:25 AM
Windows Don't Work After Battery Disconnected marlin hauser New Members Check In 1 05-06-2009 02:49 PM
Battery change on 2005 525i cindysuecj FAQ's and DIY's 1 04-05-2009 07:34 PM
'94 525i Battery Keeps Dying rita27 5-Series (E12,E28, E34, E39, E60) 4 08-28-2006 10:34 PM
Disconnecting Battery On '93 525i DANSBMW 5-Series (E12,E28, E34, E39, E60) 2 03-03-2005 05:22 AM
