How Do I Pull The Ignition Key Cylinder On A 525i - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 04-24-2005, 12:22 PM Thread Starter
vifa84 is an unknown quantity at this point
Hello,
I have a 1992 525I with a bad key cylinder. I took the column apart checked the electrical piece and it's ok. The key cylinder is bad as it doesn't turn the shaft but I can't really see how to pull it out. It looks like I might need a special tool to do it. Could someone help me out? I hope you don't have to pull the whole assembly which is attached to the steering.
vifa84 is offline
post #2 of 4 (permalink) Old 04-24-2005, 02:05 PM
If you look where the key goes in around the edge of the barrel these a cut-away this take a 2mm pin but you can use an Allen key you have to turn the key to between off and terminal R then the pin will go all the way in and you can pull the barrel out by the key
bad man working is offline
post #3 of 4 (permalink) Old 04-26-2005, 02:15 PM Thread Starter
[snapback]337186[/snapback]
I found the cut away your talking about and I tried my smallest allen key and it is a little too big. I wonder if a paper clip would work? Thanks for the info.
vifa84 is offline
post #4 of 4 (permalink) Old 04-27-2005, 01:40 PM Thread Starter
Where is terminal r? Do you mean run? I tried a paper clip and it doesn't seem to go in until the key turns almost to start. It slips in about an inch or so but I can't pull out the cyllinder. Any other idea's. I'll go to the auto parts store and see if I can find a smaller allen key.
vifa84 is offline
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 01:48 PM
How Do I Pull The Ignition Key Cylinder On A 525i, asacj 5-Series (E12,E28, E34, E39, E60) 4 04-28-2005 02:17 PM
"Spinning" ignition cylinder LloydM 3-Series (E36) 1 08-30-2004 08:04 PM
92 525i ignition lock cylinder has locked JAHDESS 5-Series (E12,E28, E34, E39, E60) 0 06-25-2004 12:09 PM
90 525i - bad ignition coil? thebaldguy 5-Series (E12,E28, E34, E39, E60) 1 04-26-2004 03:38 PM
