How to add tranny fluid - BMW Forum - BimmerWerkz.com
Old 07-26-2004, 08:40 PM   #1 (permalink)
beautyland is an unknown quantity at this point
Cool
Greetings,
When I changed the radiator, I lost about 1 qt of tranny fluid. How can I put that back? Is that simple fo refill? Is there a dipstick to check the level? If there is one, I guess I can pour some through that hole !!
1995 525i E34 Automatic
Thanks
beautyland is offline   Reply With Quote
Old 07-26-2004, 09:36 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
The fluid pours in through that hole where you check it.
I just don't know how you lost so much... I lost like 10 mL when we took my radiator out.
Old 07-26-2004, 09:38 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Sorry I didn't read your post correctly.
On my 1990 525i (M20 engine; yours is a M50) there is a tube type thing sticking up next to the firewall on the drivers side of the engine and you pour through there. I'll see if it's visible in one of the pictures of my engine that I have.
Old 07-26-2004, 09:41 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I believe it's this right here (hard to tell in the pic since there is so much stuff).
The engine is different, but I believe the 'dipstick' is in the same place since the trannies are the same.
Old 07-27-2004, 12:42 AM   #5 (permalink)
frank3 is an unknown quantity at this point
ok...so now you have me going...is this a newbie trick or what? How do you lose transmission fluid changing the radiator?
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 07-27-2004, 01:02 AM   #6 (permalink)
mated with the m50 engine is usually a sealed tranny with no dipstick, you'll need to find the fill hole...
read here : http://www.bmwe34.net/e34main/Maintenance/...20Autotrans.pdf
Maybe you could fill me in too... how do you lose tranny fluid when replacing a radiator??
Old 07-27-2004, 08:24 AM   #7 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Automatics have a hose going to the bottom of the radiator. It takes the fluid to the radiator to get it cooled (this is only for automatics though). So when you take the radiator out, you also have to take this hose off and then it leaks if you don't point it upwards or something.
Old 07-27-2004, 01:58 PM   #8 (permalink)
woah!... lol - I've never heard of that, thats crazy....
well thanks for fillin me in
Old 07-27-2004, 05:18 PM   #9 (permalink)
I'm still having problems understanding (dense? maybe). The tranny fluid would have to go through separate cooling coils in the radiator...certainly can't mix with the regular coolant...so does that mean that the radiator is a two-in-one radiator? I know some cars have separate transmission coolers...but this is a first for me.
Old 07-27-2004, 06:25 PM   #10 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
If I remember correctly the bottom (quarter maybe) is separate from the rest and only tranny fluid goes through it.
edit: By separate I mean just separate compartments, not physically separated.
Old 06-16-2005, 06:47 PM   #11 (permalink)
barber380 is an unknown quantity at this point
[snapback]153506[/snapback]
hello mate
my coolant has gone creamy n nasty with oil mixed in it,whats happend dya reckon?
cheers
[COLOR=blue][SIZE=7][FONT=Optima]
barber380 is offline   Reply With Quote
Old 06-17-2005, 01:37 AM   #12 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
nasty leak somewhere along the line. could be expensive. Only way I can see oil mixing is if its happening somewhere inside the engine itself.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 06-17-2005, 05:54 AM   #13 (permalink)
da_administrator
da_bull's Avatar
Yup, if it looks like chocolate milk, you probably have a blown head gasket, between a coolant and an oil port. Thats the big downfall of an aluminum head, once you overheat them, they're toast....
Old 06-22-2005, 03:20 PM   #14 (permalink)
it isnt engine oil,its transmission fluid mixing with coolant!.all i can try is new rad,its gotta be where its mixing.any one come across this before?.
Old 06-26-2005, 05:33 AM   #15 (permalink)
Originally posted by beautyland@Jul 26 2004, 07:40 PM
Greetings,
Thanks
[snapback]153017[/snapback]
hi
how was it changing rad,any hints or tips you could give me
thank you
Where can I get Shell LA 2634 Tranny Fluid jazzbass 5-Series (E12,E28, E34, E39, E60) 1 10-07-2005 08:09 PM
Tranny Fluid Level Check Beanster 3-Series (E36) 3 05-31-2005 09:12 PM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 03:38 PM
manual tranny fluid nycbmw325is Bimmer Talk/Motorsports Talk 1 08-09-2004 04:16 PM
Just changed my own tranny fluid Autotechnica 3-Series (E36) 7 04-30-2004 09:15 AM
