High pitch noise from transmission - BMW Forum - BimmerWerkz.com
Old 09-15-2008, 09:38 PM   #1 (permalink)
pulafets is on a distinguished road
It seems that i get a high pitched noise from my engine or transmission. its a 1998 e39 with 60k miles on it. at 65mph-75mph i get a noise likes someone is vacuuming next door form the engine compartment. it is louder in 5th gear, and not so loud in 4th gear, but only between that speed. It does not seem to be connected to the rpm because it make the noise in different gears. im worried it seem to be getting louder. anyone????? also what mileage do u change water pump???? thx
pulafets is offline   Reply With Quote
Old 09-16-2008, 09:32 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sounds to me like, the rear diff, the sound will travel through the whole car.
Old 09-16-2008, 08:07 PM   #3 (permalink)
get an oil change maybe???
Old 09-17-2008, 04:35 AM   #4 (permalink)
marti5's Avatar
Yea go for that first and change the gearbox oil at the same time, If it still does it I would say your diff is shot
Old 09-19-2008, 09:06 PM   #5 (permalink)
i forgot to mention that it only does when i push the acceleration at those speeds, if i let go it goes away completely
Old 09-19-2008, 09:11 PM   #6 (permalink)
what does a shot diff cost??? also what about the water pump when do u have to change it, does bmw have a timing chain or timing belt???
Old 09-20-2008, 02:00 PM   #7 (permalink)
Car: E34 530 V8 Auto, E36 1997 M44
OWarrior is on a distinguished road
i had the same problem with my Auto. if you have an auto gearbox, change the oil and filter. then check again. if symtoms persist, (or if u get this sounds at these speeds whatever gear you are in then goto the diff) changed my oil and filter and shhHhHhhhh!!! sound went away
OWarrior is offline   Reply With Quote
Old 09-20-2008, 02:07 PM   #8 (permalink)
chinonca's Avatar
chinonca is on a distinguished road
What kind of tranny does she have?? Sounds like a manual!
chinonca is offline   Reply With Quote
Old 09-20-2008, 11:13 PM   #9 (permalink)
yes it is a manual and the sound only comes on if i accelerate if i let off the pedal at that speed it goes away?? if it were the diff it would sound even if i did not accelerate. right??
Old 09-21-2008, 03:09 AM   #10 (permalink)
chinonca's Avatar
Yes thats correct, sounds more like a pilot bearing noise or possibly input shaft bearing noise. Make sure your tranny has fluid in it
Transmission noise carlehar 1,6,7,8 - Series and Mini Cooper 1 06-24-2008 08:30 PM
Clutch or Transmission Noise - Help Jmiller911 3-Series (E46, E90) 2 10-15-2006 09:18 AM
Transmission Light / High Rev bmwultdrivinmach 3-Series (E36) 2 04-11-2005 01:30 PM
high pitch whine at 1500rpm Cronk325i 3-Series (E46, E90) 0 08-02-2004 04:47 PM
Help! 318I making horrible high pitch sound! jroberts312 3-Series (E36) 3 07-05-2004 08:15 AM
