Hi Everyone! "heating wont blow thru vents" - BMW Forum - BimmerWerkz.com
Old 12-05-2008, 01:58 PM   #1 (permalink)
ipolovina is on a distinguished road
Question Hi Everyone! "heating wont blow thru vents"
I recently replaced a heater core and water pump on my 530I 94 bimmer and now it wont blow any hot air thru any vent, the blower motor works fine I just don't know what might be cousing this. Does anybody has anything in mind?
ipolovina is offline   Reply With Quote
Old 12-05-2008, 02:06 PM   #2 (permalink)
Something must be amiss with the ducting or the controller that decides which vents are in use.
Old 12-05-2008, 03:53 PM   #3 (permalink)
vincentmb615's Avatar
Car: 94 325i two toned full body kit
vincentmb615 is on a distinguished road
Send a message via AIM to vincentmb615
is hot only throught the defrost im guessing the system the system was bled? inside the cabin is the heater core. The engine warms up coolant and when you turn the knob to heat the air inside, coolant flows through. Outside air flows across this radiator and blows heat onto you. When you drain the coolant system you also drain the heatercore. When you fill the coolant back up, a large air bubble is trapped in the heater core. When you turn on the heat inside, that air bubble goes out and into the engine. I would check your coolant level immediately and bleed the system.
When bleeding the system, turn the heat on full-blast (high temp) while you let air escape from the bleeder screw.
Good luck,
vincentmb615 is offline   Reply With Quote
Old 12-08-2008, 05:01 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Did you reconnect the stepper motors behind the dash?
Radio/CD wont play.... Shows "PHONE" slindme 3-Series (E46, E90) 6 10-26-2008 07:21 PM
""*:·.-:¦:-·* 2001 330Ci MUST SELL ~ GREAT COND. $15000 ""*:·.-:¦:-·* bmwchic Cars For Sale 0 08-19-2008 01:36 PM
'83 733i gas tank cover wont open "electrical?" dean_290 1,6,7,8 - Series and Mini Cooper 1 01-31-2007 07:05 AM
"key in ignition?" & "Lights On?" indicator DonMatmon 5-Series (E12,E28, E34, E39, E60) 1 12-01-2006 09:47 AM
E36 M3 Luxury vs. "Sport" or "Normal" rlearp M-Series (M1, M3, M5, M6) 3 07-09-2004 06:56 AM
