Help.... Trans Program Problem - BMW Forum - BimmerWerkz.com
Old 02-10-2009, 04:55 PM   #1 (permalink)
Car: 95 540I
95tanbimmer540 is on a distinguished road
Does Anyone Know What Can Cause A Trans Program To Come Up On Dash Indicator. My Car Has Shifted Into Safe Mode Twice. What Are Some Things I Can Check (mabey Lose Wires Or Connections). It Has Done It Twice While Turning. If You Have Any Ideas Please Let Me Know. I Need To Get Her Fixed..................
95tanbimmer540 is offline   Reply With Quote
Old 02-11-2009, 12:59 AM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
^ low fluid? all of the fluid sloshing to one side
1992 318i Coupe parts car
I am Captain Obvious
Old 02-11-2009, 04:57 AM   #3 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
What does safe mode mean??!!!!
rashid is offline   Reply With Quote
Old 02-11-2009, 06:29 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
It means get me home safely as im not well!!!, and in 3rd gear basically, so you dont damage anything.
When was the last time the box got a service? should be 80,000miles then 30-40,000 thereafter.
Old 02-11-2009, 08:12 AM   #5 (permalink)
Car: 95 540I
not sure just bought the car. it has 230.000 miles on it
Old 02-11-2009, 10:39 AM   #6 (permalink)
marti5's Avatar
Ok, Im guessing thats its due for a box service, I would not be surprised if its never had one, get it done asap also whilst your at it get the rear diff oil changed.
Old 03-01-2009, 06:58 PM   #7 (permalink)
raakevin is on a distinguished road
Did you ever find out what was wrong my car doing the same thing.
raakevin is offline   Reply With Quote
Old 03-02-2009, 08:43 PM   #8 (permalink)
Car: 95 540I
trans program
not yet, i changed the a/m selector switch next to shifter. i was told that is common to go out and cause the problem but it did not help. the next thing i might try is the differential speed sensor.it is a fairly cheep repair. if it works i will let you know, but it might be a while, so if you fix yours first please let me know. thanks.......................
Old 03-03-2009, 02:46 AM   #9 (permalink)
marti5's Avatar
So I presume you have given it a fluid a filter change ????
Old 03-03-2009, 09:14 PM   #10 (permalink)
Car: 95 540I
not yet, that is also the next step. the TRANS PROGRAM in the owners manual says that the transmission control module is at fault, do you have any knowledge of this..
Old 03-04-2009, 03:29 AM   #11 (permalink)
marti5's Avatar
The transmission control unit (TCM/EGS) is located in the "E" box. This is in the engine compartment at the top right side, there are 4 phillips screws holding the cover on.
Once the cover is removed the TCM/EGS will be visible. The order will vary depending on model year.
Trans Program camper1159 5-Series (E12,E28, E34, E39, E60) 1 04-10-2009 08:38 PM
e-34 Trans Program Question 4-BMW's 5-Series (E12,E28, E34, E39, E60) 0 11-05-2008 03:23 PM
'94 525i trans program MalinT 5-Series (E12,E28, E34, E39, E60) 8 01-21-2008 08:41 PM
Trans Program Bunny Capricorn 5-Series (E12,E28, E34, E39, E60) 1 04-12-2005 07:15 AM
Trans program Hoopty 5-Series (E12,E28, E34, E39, E60) 7 01-04-2004 03:25 AM
