Help!Ticking engine bay! - BMW Forum - BimmerWerkz.com
Old 12-03-2007, 12:19 PM   #1 (permalink)
murray195 is on a distinguished road
Exclamation Help!Ticking engine bay!
Before you guys rag on me, I've searched the forums as well as google haha. I was a jap import guy not too long ago so this is... well... german to me I guess you'd say ha.
I have a 1989 525i and have noticed a ticking noise in the engine compartment. It doesnt really sound like something internal, more electrical. It sounds like the tick your battery post can make when you reconnect the positive but more constant and rapid.
I thought maybe it was the exaust manifold (maybe a crack or something) but it's pretty hard to tell. It actually would make sense if it was the timing but the car runs great and thats computer controlled anyways... anybody experienced this before? its not a very subtle noise when the hood is open.
Any help would be greatly appreciated!
murray195 is offline   Reply With Quote
Old 12-03-2007, 01:46 PM   #2 (permalink)
Pswirley's Avatar
Car: Mountain Killer
Pswirley has a spectacular aura aboutPswirley has a spectacular aura aboutPswirley has a spectacular aura about
Valve tick, fairly common in our cars. Try a 20/50 full synthetic. Others have said that if you add an extra quart of oil when you do this it helps or Risoline in with the oil also helps.
Pswirley is offline   Reply With Quote
Old 12-03-2007, 01:54 PM   #3 (permalink)
Thumbs up Thanks
Thank you for the advice, I'll give that a shot! Is this something I should be concerned about? Or is it just the car's personality haha
Old 12-03-2007, 01:58 PM   #4 (permalink)
Pswirley's Avatar
I just live with it.
Old 12-03-2007, 02:03 PM   #5 (permalink)
Thumbs up ok
haha, fair enough. I did some research on that risoline and it sounds like a good fix... or band-aid anyways. Thanks again!
Old 12-03-2007, 11:39 PM   #6 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
The real problem is this. Your valve cover gasket is leaking. If you pull out one of the spark plugs, I'm betting you will see oil fouling on the plug and if the leak is considerable, the plug connector boots may be oil damaged or you may see oil sitting on the outside of the plug itself.
If you replace the valve cover gasket and change your spark plugs it will go away... make sure to use silicone on the gasket as well if you want the fix to last. I've replaced the gasket on my car twice in the past year... and i'm sure it will come back again eventually... But it's just a valve tap... if it's annoying enough... theres your fix.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 12-04-2007, 12:44 AM   #7 (permalink)
Sounds good
Thank you for the explanation and solution. I was pretty concerned at first that I may be getting into electrical, and as a previous honda/nissan/toyota guy it would be an experience and a half!
Thanks,
Kayle
Old 12-04-2007, 02:45 AM   #8 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
lol toyota's electrical compared to bmw's is like a lamp compared to a super computer.....
1992 318i Coupe parts car
I am Captain Obvious
Old 12-04-2007, 07:21 AM   #9 (permalink)
yeah the second something electrical starts fscking up on a bmw... it's time to get a diffrent bmw.
Old 12-04-2007, 05:28 PM   #10 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
for some reason i dont think this is the problem to be honest with you... if youve changed the gasket 2wice in the last year then why do you believe it is?? sure the oil in the spark plug area is a leaky valve cover gasket but from what i know i think there is an oil valve in the head itself that fails over time and doesnt keep oil in the head as well as it did from the factory...
your best bet is exactly what pswirley said...
Old 12-04-2007, 11:04 PM   #11 (permalink)
Pswirley's Avatar
Gave teh feedback, its supposed to be lawlz.
Old 12-08-2007, 12:39 AM   #12 (permalink)
His car has the m20, not the m50, so a leaky valve cover gasket rarely fouls the plugs unless its real bad.
Also, I'm not sure if its a great idea to put synthetic oil in that car unless it has already been switched over. Leaks all over the place aren't so fun. And I wouldn't add an extra qt. over whats recommended. The car will just quickly burn it off. An oil additive such as lucas oil stabilizer MIGHT help a little bit.
The real problem is the ol' m20 engine just needs a little valve adjustment. Do one every oil change and you'll be good.
Old 12-08-2007, 02:39 AM   #13 (permalink)
Pswirley's Avatar
Point taken..
I guess I wasnt paying attention to the 85 525i part.
Old 12-08-2007, 12:51 PM   #14 (permalink)
Sodium Chloride
Car: 95 M3
heh woops???
ps. personally id rather go synthetic... i mean if theres a leak somewhere thats only being plugged by old oil the hell id rather it leak, me fix it and know my engine is solid rather then cover it up with more dino juice... :\ just my 2 cents....
Old 12-08-2007, 02:25 PM   #15 (permalink)
lol usually its not just a leak somewhere, its multiple leaks.. everywhere.
I agree with you a bit, but I'm not sure if everybody has the $$ necessary to fix a whole bunch of large leaks at once.
1990 518i - engine problems and advice for a novice!! RichardMichael 5-Series (E12,E28, E34, E39, E60) 6 02-08-2006 02:18 PM
M3 Engine Swap (pics) Furious 3-Series (E36) 26 04-08-2005 07:52 PM
Engine Sputtering, Checked Alredy.. victorgallas 3-Series (E36) 0 02-24-2005 11:27 AM
