Help - Removing The Window Regulator On My 99 528i - BMW Forum - BimmerWerkz.com
Old 03-19-2005, 12:37 PM   #1 (permalink)
supercal29 is an unknown quantity at this point
I am in the middle of removing the regulator/motor from the driver's side rear door and cannot acess the torx bolt at the top. How on earth is this done? Do I remove the window? If I can just get the window up a little higher or down a little more I can reach the bolt through the small acess hole in the side of the door.
My search of the archives has so far revealed nothing. I can take pictures and post them if it will help.
Thank you. ghead
Steve
317-531-7031
supercal29 is offline   Reply With Quote
Old 03-19-2005, 12:40 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Take the inner scrub molding off so that the glass can come off. This is the felt like moulding that runs against the window on the inside edge.
DT
DT
Old 03-19-2005, 12:43 PM   #3 (permalink)
DT
[snapback]314717[/snapback]
Thank you. I actually have the trim off. But I just found this on a search http://www.bmwtips.com/tipsntricks/WindowR...r/regulator.htm and will be trying that. Hope it works.
Old 03-19-2005, 12:47 PM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
im sorry i read wrong u said drivers rear, i thought it read drivers. Rear is much easier.
DT
DT
Old 03-19-2005, 12:51 PM   #5 (permalink)
DT
[snapback]314721[/snapback]
No prob. I am going out to see if a 10mm really works...must be on the back side of the torx bolt.
Steve
Removing Window Regulators From E36 Coupe ruff ryder 3-Series (E36) 4 06-09-2005 02:03 AM
Need Carfax Report, Please Help F U Have Carfax Ac ozbmw 5-Series (E12,E28, E34, E39, E60) 2 05-11-2005 10:58 AM
Removing Window Tint crazy91318 3-Series (E21, E30) 1 04-25-2005 11:09 PM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
