help needed! 1992 bmw e34 - BMW Forum - BimmerWerkz.com
Old 05-21-2012, 10:12 PM   #1 (permalink)
Car: 1992 bmw e34
bestcareem87 is on a distinguished road
Exclamation help needed! 1992 bmw e34
so my transmission is slipping that i know i need to have rebuilded. The issue is that when i turn on the ignition the car starts but when i let it idle the revs are flutuating and sometimes eventually the engine stops.
what i have checked so far is all the hose connections in the engine bay. All hoses connected. also i have checked the airflow meter hose which is located around the air intake system. i found nothing wrong with the hose and it is connected.
Anyone help.
bestcareem87 is offline   Reply With Quote
Old 05-27-2012, 10:47 AM   #2 (permalink)
haggus's Avatar
haggus is on a distinguished road
Do you have the bentley manual if not it's a good place to start. Vaccum leaks will cause eratic idle plugged fuel filter, air filter, fuel pressure.
Also if you want more accurate help you probably want to let people know what type of engine you have. Look for DTC those are the easiest way to find and locate problems.
haggus is offline   Reply With Quote
Old 05-27-2012, 03:14 PM   #3 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
In addition to the hoses did you check your intake boot? What about under the intake manifold?
Sounds like you have a vacuum leak, or your ICV or PCV valve has gone bad. Their is a PDF copy of the Bentley Manual available which will definitley help.
Click HERE to see my E36 Blog
Old 05-29-2012, 09:12 PM   #4 (permalink)
Car: 1992 bmw e34
thanks to all i'm going to go buy a code reader n also i will check my bentley manual.
I'll let all know how it goes
thanks again
Needed Water Pump For A 520 1992 M50 Lump j.leggz 5-Series (E12,E28, E34, E39, E60) 1 05-16-2005 05:01 PM
1992 318 shane 3-Series (E36) 0 03-20-2005 11:52 AM
my 1992 YNGRVP Picture Showroom 3 06-11-2004 07:49 PM
1992 352's?? banginbimmer 3-Series (E36) 1 02-10-2004 11:33 PM
1992 325's??? banginbimmer 3-Series (E36) 3 02-10-2004 11:52 AM
