Help with my 97 528 - BMW Forum - BimmerWerkz.com
Old 03-15-2012, 07:49 PM   #1 (permalink)
MK4SWAGN is on a distinguished road
Help with my 97 528
Today while at the carwash my 97 528 caught a missfire. It was running good all day. I got an oil change, replaced brake pads and rotors, also had my spark plugs replaced (NGK copper). My ABS, Brake and Traction lights are on what can this be. These lights were on before the brake job. I purchased the car yesterday dirt cheap and figured it would be worth it. Thanks
MK4SWAGN is offline   Reply With Quote
Old 03-16-2012, 10:06 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
When you replace your brake pads you also need to replace your Brake Pad Wear Sensor. Their one time use. About $14 at the dealership.
Click HERE to see my E36 Blog
Old 03-16-2012, 10:12 AM   #3 (permalink)
Thanks! What do you think can be causing the misfire? This morning i went start it up and it was just fine.
Old 03-16-2012, 10:39 AM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
A misfire is normally caused by a spark issue. Be it the plugs, coils, or coil boots. Check your coil boots as they can crack with age and can cause reduced spark efficiency.
Old 03-18-2012, 07:22 AM   #5 (permalink)
I appreciate the help...
Old 03-18-2012, 07:30 AM   #6 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Your welcome.
If this helped please don't forget to click the rep button!
Old 03-18-2012, 07:49 PM   #7 (permalink)
By any chance do you know of anyone who rebuilds the ABS modules. I really like this car and would like to have it on point with everything. Its just in need of some TLC.
Old 03-18-2012, 07:51 PM   #8 (permalink)
I also found out my check engine code, P0500 cylinder 3 misfire. Any ideas?
Old 03-19-2012, 01:03 AM   #9 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Acording to my OBD Codes PDF:
P0500 Vehicle Speed Sensor Malfunction
P0305 Cylinder 5 Misfire Detected
Is that what the code reader said, or did it just spit out P0500?
Old 03-19-2012, 07:51 AM   #10 (permalink)
P0500
P0303: cylinder 3 misfire
Old 03-19-2012, 08:19 AM   #11 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
The code that showed up was P0500? Or both?
Old 03-19-2012, 09:05 AM   #12 (permalink)
both
