Help... Lost 2nd gear - BMW Forum - BimmerWerkz.com
Old 04-15-2008, 10:56 PM   #1 (permalink)
jh2pizza is on a distinguished road
I own a 94 525I, was on the way to work today, driving 55, had a slow down on the freeway, dropped it into 2nd. Everything seemed fine until I accelerated and went to shift into 3rd gear. At first, I could hardly shift it out of 2nd. I had to fight with it, Once I got it to shift, I can not get back into 2nd for notthing. It grinds when tried. All the other gears work perfect.
jh2pizza is offline   Reply With Quote
Old 04-16-2008, 02:08 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
sounds like the syncro went.... Question how har do you shift into second? and be honest it will help in diagnosing....
1992 318i Coupe parts car
I am Captain Obvious
Old 04-16-2008, 02:30 PM   #3 (permalink)
I second that opinion.
Old 04-16-2008, 03:42 PM   #4 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
Yep, grinding gear... bad synchromesh gear... transmission needs to be pulled to replace. I have had same issue in mazda Rx7, Mustang GT, Prelude Si...
Can you get it in if you hold the clutch, rev the engine, then pull slightly on it as the revs go down? It should engage when the gear speeds match up. i used to have to do that in my prelude, it would almost have to come down to an idle before I could shift it in without it grinding. But i can almost guarantee that if all your other gears work fine, its the 2nd gear synchro that is worn out. 2nd gear the most common synchro to go, mainly caused by hard shifting. dont feel bad - all of us do it.. 'cept me anymore since I have an automatic..
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
97 328i auto - Hard 2nd to 3rd gear shift Othniel13 3-Series (E36) 3 03-14-2007 10:03 AM
Car Shivers When Accelerating In 2nd Gear? Delmarco Other Rides 15 09-08-2005 08:40 PM
2nd Gear Trans. Problem? bondmanz8 3-Series (E36) 1 09-10-2004 10:00 PM
2004 - 330i Gear Shift grind 1st - 2nd mtarchal 3-Series (E46, E90) 1 04-08-2004 09:54 PM
Car Shivers When Accelerating In 2nd Gear? Trajiq 3-Series (E36) 0 12-31-1969 07:00 PM
