Help Extended Crank - BMW Forum - BimmerWerkz.com
Old 11-03-2010, 06:20 PM   #1 (permalink)
yellowistheway is on a distinguished road
Help Extended Crank
I posted earlier (see "Battery or Alternator or Something else?), but thought maybe this subject line would be more accurate. I have a 2000 528i that has just had the CCV and throttle body replaced a month ago. Now, I am noticing when I start the engine, there is an extended crank. I used to be able to turn the key and the car would start almost immediately. This has been going on for a week now. Once it starts, it is fine. It just usually turns longer before actually starting. I am hoping it's just the battery, but any other thoughts would be appreciated! (I had the battery changed a couple of years back, but I live in the desert so they tend to go dead faster).
yellowistheway is offline   Reply With Quote
Old 11-04-2010, 11:37 PM   #2 (permalink)
Car: 1994 530i
whitey is on a distinguished road
If it cranks at normal speed and just takes longer to start it might not be the battery, Have you changed the fuel filter or spark plugs lately? PS a battery should last longer in a warmer climate as the acidity level will be higher then those of a colder climate.
Ashley.
whitey is offline   Reply With Quote
Old 01-27-2011, 11:17 AM   #3 (permalink)
I had the fuel filter changed after your response (not at the dealership, who didn't even recommend this) with a private mechanic and now it runs nicely. Thanks!
Extended Warranties rundawg 1,6,7,8 - Series and Mini Cooper 6 11-04-2009 04:56 AM
DOESN'T CRANK . . . . sometimes. TeeUp 3-Series (E36) 4 04-25-2006 02:26 PM
M3 Extended Warranty??? sushilgour M-Series (M1, M3, M5, M6) 2 03-28-2006 06:46 PM
Extended Warranty GeneNJ 3-Series (E46, E90) 4 12-16-2004 12:09 PM
Extended Warranty jazzmanrock 5-Series (E12,E28, E34, E39, E60) 0 07-22-2004 05:19 PM
