help, exhaust problem - BMW Forum - BimmerWerkz.com
Old 02-15-2006, 03:16 PM   #1 (permalink)
walshja is an unknown quantity at this point
on my wifes car, 199 528iT, the exhaust pipe going from the first muffler to the second muffler which is located underneat the middle of the car, has dislodged from the pipe to the second muffler. apparantly there are 3 mufflers on these cars? is that correct?
my wife went to a local garage, not our normal mechanic, and received a quote of $1400 to fix. the mechanic claims the entire enhaust must be replaced.
is that true?
HELP
1994 325iC, 130k miles
walshja is offline   Reply With Quote
Old 02-15-2006, 04:26 PM   #2 (permalink)
///Matt's Avatar
Ah, a fellow Walsh...Replacing the entire exhaust because of a dislodged pipe is nuts... This should be a simple fix that might require a new muffler at worst or a well skilled welder at best. Here are some EPC images so you can get a better view of what the exhaust system looks like. The middle "muffler" that you describe is what BMW calls a "Center Silencer." Which sounds like the same thing, but isn't. It's wishbone shape quiets the noise and sends the exhaust gas to the rear muffler. Gotta love that German confusing engineering...
Old 02-15-2006, 04:54 PM   #3 (permalink)
matt, AWESOME !!!
I shall figure out exactly what is wrong with these pictures !!!
THANKS !!
although I am having difficulty figuring out how the first picture relates to the second.
if I was to line them up in the proper order, the right side of the first picture would line up with the left side of the second picture? so the single pipe coming out of the front muffler (on the right) goes into the single pipe into the middle silencer?
is that right?
again, THANKS !!!!
Old 02-15-2006, 06:20 PM   #4 (permalink)
///Matt's Avatar
This should make it a little clearer...
Old 02-16-2006, 04:42 PM   #5 (permalink)
matt, your help I believe saved me $1250 !!!
after getting your pictures, I got under the car and saw that the pipe going from the front muffler to the center silencer was disconnected. I want to say disconnected because I really didn't see any corrosion, but it was simply disconnected at a weld location.
So, knowing exactly what was wrong I went to my normal mechanic, told them what was wrong and had the 2 pipes welded together. They did the weld, checked for leakes, and 2 hours later I was out the door for $150 !!
They had to lower the entire exhaust from the car, I guess it's bolted to the transmission and engine, then hung from the body of the car with hangers. For them to weld on top of the pipe, the entire exhaust system had to be lowered.
and the shop did confirm that the entire exhaust is sold in 1 piece, not looking forward to that day !!
Old 02-17-2006, 05:38 PM   #6 (permalink)
BeelZibub is an unknown quantity at this point
The entire exhaust is sold in several pieces
1: Manifolds
2ownpipes
3:Catalyst
4:Centerbox
5:Rear Box
My cat went, but rather than pay the £660 +vat & fitting for a BMW cat I paid £600 all in for a full custom stainless mid sports system consisting of a Highflow Catalyst, Center box and rear box - Sounds great and lets her breath out better which compliments the K&N intake.
BeelZibub is offline   Reply With Quote
Perplexing Problem Starting my 87 528e arkhaus 5-Series (E12,E28, E34, E39, E60) 5 02-04-2006 08:17 AM
Exhaust Problem... maybe TOA 5-Series (E12,E28, E34, E39, E60) 4 12-26-2005 10:39 AM
Need Help!1987 325es: Exhaust Leak/runscrappy pettas 3-Series (E21, E30) 12 12-11-2004 05:12 AM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
