Help with brake warning on my 06 525xi - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 09-06-2009, 06:04 AM Thread Starter
bimmernut is on a distinguished road
Hello Everyone,
I recently had my front and rear brake pads replaced including the brake sensors at a local Mavis Tire Center. I have been driving the car now for about a month with the new pads and sensors. Last week the low brake pads warning came on. I took it back to Mavis and they said maybe the sensors they put in was faulty so they replaced it. The manager told me that they replaced the sensor but the light is still on so he thinks I need to have it checked at the dealer. My questions is does the manager knows what he is talking about? Do you guys think I have to bring it to the dealer? Or do you think it is something that needs to be reset by a scan tool? Any advise or input is greatly appreciated. Thanks to all in advance for your help. FYI. The car no longer has a warranty since it has 57,000 miles on it.
bimmernut is offline
post #2 of 5 (permalink) Old 09-06-2009, 06:20 AM
Help from over the pond
marti5's Avatar
Try this its for E65, My mate had the same problem, luckily I kept the write up on it...
After you changed your pads and sensors, to rest the mileage indicator/pad light etc:
--------Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost"."
marti5 is offline
post #3 of 5 (permalink) Old 09-07-2009, 07:04 AM Thread Starter
Hints & Tips
Marti5,
I just want to thank you so much for your response and sharing the above information. You saved me!!! I never knew you could do all the above mentioned. It worked great. I was able to reset my brake fluid warning and my rear brake warning. I think they should consider putting your write up as a sticky for others to use.
post #4 of 5 (permalink) Old 09-13-2009, 09:45 AM
will3hawks is on a distinguished road
brake light problems
Not to be a snob but you don't go to a general practioner for brain surgery. If you chose not to go to the dealer for service, find someone who is trained to work on German cars. Look for Bosch trained technicians who know the systems on German cars.
will3hawks is offline
post #5 of 5 (permalink) Old 11-06-2009, 07:20 PM
roadrunner2008 is on a distinguished road
Well you would go to a general practioner before he sends you to the brain surgen
So why not come here and get advice first rather than going straight to a dealer and getting charged an extortionate fee for something you can do yourself !
Thanks marti5 your help is much appreciated
roadrunner2008 is offline
Help me locate brake fluid reservoir on 525xi bimmernut 5-Series (E12,E28, E34, E39, E60) 0 06-25-2009 01:19 PM
Brake Linings warning greenbw 5-Series (E12,E28, E34, E39, E60) 2 06-22-2009 03:46 PM
Brake Light Circuit Warning? Laker 3-Series (E36) 10 08-31-2004 11:00 PM
warning Brake light ON??? mnguyen11111 5-Series (E12,E28, E34, E39, E60) 10 07-15-2004 07:35 PM
Brake Lining warning Light Jefbrunton 5-Series (E12,E28, E34, E39, E60) 1 11-29-2003 07:25 AM
